Dear Zammad-Community,
hope you can help:
Zammad Machine
Used Zammad version: Zammad 3.6
Used Zammad installation source: RPM
Operating system: SLES 12.5
Browser + version: Chrome 87.0.4280.88 (64-Bit)
Additional: 4 Cores, 12 GB RAM
OTRS Machine
Used OTRS version: OTRS 4.0
Used OTRS installation source: RPM
Operating system: SLES 11.4
Migrator Module Version: 4.1.11
Migrator Repo Version: 4.0.25
Additional: Virtual Machine with 16GB RAM, 4 Cores
- Imports all Tickets (round about 5,5k) from OTRS to Zammad.
Tried two hardware configurations for the OTRS virtual machine, each results in different errors.
** 2 Cores, 2 GB RAM, 1 GB Swap **
- Round about 2,1k of 5,5k gets imported into Zammad.
- Threads dying due to out of memory error until no thread is alive anymore, than the whole process closes himself.
Tried to incease the amount of Memory and Cores of the OTRS Machine to prevent the memory error and a lack of performance.
** 4 Cores, 16GB Ram, 1 GB Swap **
- After 600 Tickets, the OTRS Machine is responding very slow (ssh session, enter commands).
- The OTRS Migrator throws ReadTimeOut Errors, because the load on the OTRS Machine is very high:
thread#6: ERROR: #<Net::ReadTimeout: Net::ReadTimeout>
#<Thread:0x00005597f4e270c0@/opt/zammad/vendor/bundle/ruby/2.6.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:471 run> terminated with exception (report_on_exception is true):
9: from /opt/zammad/vendor/bundle/ruby/2.6.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in block in create_with_logging_context' 8: from /opt/zammad/lib/import/otrs.rb:102:in
block (2 levels) in threaded_import’
7: from /opt/zammad/lib/import/otrs.rb:102:in loop' 6: from /opt/zammad/lib/import/otrs.rb:108:in
block (3 levels) in threaded_import’
5: from /opt/zammad/lib/import/otrs.rb:144:in imported?' 4: from /opt/zammad/lib/import/otrs.rb:150:in
import_action’
3: from /opt/zammad/lib/import/otrs/requester.rb:35:in load' 2: from /opt/zammad/lib/import/otrs/requester.rb:80:in
request_result’
1: from /opt/zammad/lib/import/otrs/requester.rb:93:in request_json' /opt/zammad/lib/import/otrs/requester.rb:133:in
post’: Zammad Migrator returned an error (RuntimeError)
9: from lib/import/otrs.rb:102:in block (2 levels) in threaded_import' 8: from lib/import/otrs.rb:102:in
loop’
7: from lib/import/otrs.rb:108:in block (3 levels) in threaded_import' 6: from lib/import/otrs.rb:144:in
imported?’
5: from lib/import/otrs.rb:150:in import_action' 4: from lib/import/otrs/requester.rb:35:in
load’
3: from lib/import/otrs/requester.rb:80:in request_result' 2: from lib/import/otrs/requester.rb:93:in
request_json’
1: from lib/import/otrs/requester.rb:133:in `post’
RuntimeError (Zammad Migrator returned an error)
irb(main):007:0> thread#1: ERROR: #<Net::ReadTimeout: Net::ReadTimeout>
(Content Collapsed)
Not exactly reproducable. Tried multiple times with same Settings and the appearence of the Errors are each time different.
Now i want to ask, if it is possible to reduce the amount of threads which gets generated, to reduce the parallel workload.
I would be happy about every suggestion you have for me
