Did you verify the combination of protocol and port you are using with a mail client? Port 993 is for secure Imap, not secure POP so the combination in the screenshot is probably not working because of that. I would recommend using IMAP with 993 but you have to ensure this is enabled on your mailserver and the credentials are correct. Easy to test with a mail client.
