- some extracts from migration update log:
[root@support conf.d]# zammad run rails db:migrate --trace
** Invoke db:migrate (first_time)
** Invoke db:load_config (first_time)
** Execute environment
** Execute db:load_config
** Execute db:migrate
== 20171213000001 ChangeAuthorizationTokenSize: migrating =====================
– change_column(:authorizations, :token, :string, {:limit=>2500})
-> 0.0731s
== 20171213000001 ChangeAuthorizationTokenSize: migrated (0.0761s) ============
== 20180108000001 ChangeExchangeExternalSyncIdentifier: migrating =============
== 20180108000001 ChangeExchangeExternalSyncIdentifier: migrated (0.0030s) ====
== 20180111000001 LdapSamaccountnameToUid: migrating ==========================
== 20180111000001 LdapSamaccountnameToUid: migrated (0.0437s) =================
== 20180116000001 SettingTicketNumberIgnoreSystemIdSupport: migrating =========
== 20180116000001 SettingTicketNumberIgnoreSystemIdSupport: migrated (0.0237s)
== 20180128000001 ChatAddIpCountry: migrating =================================
– add_column(:chats, :block_ip, :string, {:limit=>5000, :null=>true})
-> 0.0343s
– add_column(:chats, :block_country, :string, {:limit=>5000, :null=>true})
-> 0.0005s
== 20180128000001 ChatAddIpCountry: migrated (0.0360s) ========================
== 20180202000001 SidebarCustomerOpenTicketColored: migrating =================
== 20180202000001 SidebarCustomerOpenTicketColored: migrated (0.0260s) ========
== 20180202000002 CustomLdapLoginAttribute: migrating =========================
== 20180202000002 CustomLdapLoginAttribute: migrated (0.0075s) ================
== 20180220000001 SettingAttachmentPreview: migrating =========================
== 20180220000001 SettingAttachmentPreview: migrated (0.0402s) ================
== 20180220000002 SettingUserOrganizationSelectorWithEmail: migrating =========
== 20180220000002 SettingUserOrganizationSelectorWithEmail: migrated (0.0237s)
== 20180220171219 CheckForObjectAttributes: migrating =========================
== 20180220171219 CheckForObjectAttributes: migrated (0.8810s) ================
== 20180226085743 Issue1660FixTreeSelectConfigurations: migrating =============
== 20180226085743 Issue1660FixTreeSelectConfigurations: migrated (0.0022s) ====
== 20180306084119 CustomHtmlEmailCssFont: migrating ===========================
== 20180306084119 CustomHtmlEmailCssFont: migrated (0.0080s) ==================
== 20180320000001 SettingTableGroupByShowCount: migrating =====================
== 20180320000001 SettingTableGroupByShowCount: migrated (0.0241s) ============
== 20180327170847 Issue1905ExchangeLoginFromRemoteId: migrating ===============
== 20180327170847 Issue1905ExchangeLoginFromRemoteId: migrated (0.0193s) ======
== 20180410000001 CleanupUserPreferencesNotificationSound2: migrating =========
rails aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::UndefinedTable: ERROR: relation “active_job_locks” does not exist
LINE 8: WHERE a.attrelid = ‘“active_job_locks”’::regc…
: SELECT a.attname, format_type(a.atttypid, a.atttypmod),
pg_get_expr(d.adbin, d.adrelid), a.attnotnull, a.atttypid, a.atttypmod,
c.collname, col_description(a.attrelid, a.attnum) AS comment
FROM pg_attribute a
LEFT JOIN pg_attrdef d ON a.attrelid = d.adrelid AND a.attnum = d.adnum
LEFT JOIN pg_type t ON a.atttypid = t.oid
LEFT JOIN pg_collation c ON a.attcollation = c.oid AND a.attcollation <> t.typcollation
WHERE a.attrelid = ‘“active_job_locks”’::regclass
AND a.attnum > 0 AND NOT a.attisdropped
ORDER BY a.attnum
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedTable: ERROR: relation “active_job_locks” does not exist
FROM pg_attribute a
ORDER BY a.attnum
