Problem with searching the organization by query through the API
Used Zammad version: 6.4.1
Used Zammad installation type: docker-compose
Operating system: Ubuntu 22.04
Browser + version: Firebox 136.0 (64-bit)
  • I am querying the API with an value query as “test” and It does not show the data:
https://xxxxxxxxxxxxxxxxxxxx/api/v1/search/organization with the JSONdata:
“assets”: {},
“result”:
  • I would like to get data of the organizations
  • result is { “assets”: {}, “result”: }
  • see queries above
Hi @castro849. Are you using Elasticsearch? If yes, all indexes are up-to-date?
What is the use case? Normally it’s better to avoid the search approach when you want to find specific things and use condition search, because this is related to the database.
