Used Zammad version: 6.2.0-1709902372.e5509ee8.bookworm
Operating system: Debian 12
Browser + version: Latest MS Edge + all others
Scheduler should run normally
Scheduler doesn’t run normally
Can’t really reproduce the issue. We had the issue a few times now, i see it because the activity monitor doesn’t refresh and it just looks like this in the settings
What helps is just restarting the scheduler by “systemctl restart zammad-worker” - but i had to do that twice today.
Can’t really find something in the production log - maybe someone has a keyword on what to search?
+1 we’ve the same prob → any solutions ?
inv:
Debian 12
6.3.1-1720594112.300297ce.bookworm
sambucca:
You’re outdated.
The solution is to check if the scheduler is really dead and if not what delays it.
You’re outdated.
Check will update soon. But problem occurs form version 4.xxxx to still 6.3.1.
How can we check ? With puma ?
No offense, but the documentation is answering that question:
https://docs.zammad.org/en/latest/install/package.html#manage-services-of-zammad
Apart from that, you only screamed “me too”, so I won’t be able to help in more detail.
Great that solve all of our probs. Nice greetz to Berlin Marcel
Error message:
Mär 07 14:35:59 deb3-zmmd zammad-worker-1.service[1008432]: bMär 07 14:35:59 deb3-zmmd zammad-worker-1.service[1008432]: bundler: failed to load command: script/background-worker.rb (script/background-worker.rb)undler: failed to load command: script/background-worker.rb (script/background-worker.rb)
prelog:
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: #<Thread:0x00007f6f7e8b5d68 /opt/zammad/lib/sessions.rb:445 run> terminated with exception (report_on_exception >
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: /opt/zammad/lib/sessions.rb:515:in `rescue in thread_client': STOP thread_client for client .932360 after 10 tri>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions.rb:490:in `thread_client'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions.rb:513:in `rescue in thread_client'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions.rb:446:in `block (3 levels) in jobs'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/abstract/co>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapter>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/monitor.rb:202:in `synchronize'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/monitor.rb:202:in `mon_synchronize'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_handlin>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/core.rb:433:in `ca>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/core.rb:317:in `fi>
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/app/models/application_model/can_lookup.rb:30:in `block in lookup'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/auth/request_cache.rb:11:in `fetch_value'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/app/models/application_model/can_lookup.rb:29:in `lookup'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions/client.rb:36:in `block in fetch'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions/client.rb:25:in `loop'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions/client.rb:25:in `fetch'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions/client.rb:9:in `initialize'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions.rb:491:in `new'
Mär 07 14:35:58 deb3-zmmd zammad-worker-1.service[1008432]: from /opt/zammad/lib/sessions.rb:491:in `thread_client'
system
Closed
March 2, 2026, 3:22pm
8
