- Used Zammad version: 2.9
- Operating system: ubuntu 16.04
I did a dist-upgrade of my system and I have a problem upgrading to the last release of zammad.
I post here the error message. I tryed to install libimlib2 libimlib2-dev but they were already installed.
Setting up zammad (2.9.0-1557934377.16325a31.xenial) …
chown: cannot access ‘/opt/zammad/tmp/cache_file_store_production/507’: No such file or directory
chown: cannot access ‘/opt/zammad/tmp/cache_file_store_production/504’: No such file or directory
dpkg: error processing package zammad (–configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
zammad
E: Sub-process /usr/bin/dpkg returned an error code (1)
W: Operation was interrupted before it could finish
apt-get install libimlib2 libimlib2-dev
Reading package lists… Done
Building dependency tree
Reading state information… Done
libimlib2 is already the newest version (1.4.7-1ubuntu0.1).
libimlib2 set to manually installed.
libimlib2-dev is already the newest version (1.4.7-1ubuntu0.1).
libimlib2-dev set to manually installed.
The following packages were automatically installed and are no longer required:
linux-headers-4.4.0-146 linux-headers-4.4.0-146-generic
Use ‘apt autoremove’ to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
zammad
Can you help please ?
Thank you very much. I love Zammad
