Problem to Submit Trigger Changes
Info:
  • Zammad-Version: 6.5.2-1768908570.c51d4833.centos9
  • Zammad installation type used: CentOS DNF package
  • Operating system: Server CentOS 9, Client W11
  • Browser + version: MS Edge version 144.0.3719.82
I want to change the text for the auto-reply in “Triggers”.
Change the text and click on “Submit”, now nothing happens.
I have been able to reproduce this on two systems with version 6.5.2-1768908570.c51d4833.centos9.
After clicking on “Submit”, the change should be saved and the window should close.
In version 6.5.2-1766167336.889983bc.centos9 this still works.
Thanks for this report.
When you have clear, reproducible steps on a fresh, stable installation, you should create an issue on GitHub.
