- Used Zammad version: 5.x
- Used Zammad installation type: (package)
- Browser + version:
I get the following error if i try to start Elasticsearch after upgrade.
Elasticsearch log:
[2022-01-12T08:58:02,992][INFO ][o.e.n.Node ] [support] JVM home [/usr/share/elasticsearch/jdk], using bundled JDK [true]
[2022-01-12T08:58:02,992][INFO ][o.e.n.Node ] [support] JVM arguments [-Xshare:auto, -Des.networkaddress.cache.ttl=60, -Des.networkaddress.cache.negative.ttl=10, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -XX:-OmitStackTraceInFastThrow, -XX:+ShowCodeDetailsInExceptionMessages, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dio.netty.allocator.numDirectArenas=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j2.formatMsgNoLookups=true, -Djava.locale.providers=SPI,COMPAT, --add-opens=java.base/java.io=ALL-UNNAMED, -XX:+UseG1GC, -Djava.io.tmpdir=/tmp/elasticsearch-13626790051793039139, -XX:+HeapDumpOnOutOfMemoryError, -XX:+ExitOnOutOfMemoryError, -XX:HeapDumpPath=/var/lib/elasticsearch, -XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log, -Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m, -Xms7831m, -Xmx7831m, -XX:MaxDirectMemorySize=4106223616, -XX:G1HeapRegionSize=4m, -XX:InitiatingHeapOccupancyPercent=30, -XX:G1ReservePercent=15, -Des.path.home=/usr/share/elasticsearch, -Des.path.conf=/etc/elasticsearch, -Des.distribution.flavor=default, -Des.distribution.type=deb, -Des.bundled_jdk=true]
[2022-01-12T08:58:05,777][INFO ][o.e.p.PluginsService ] [support] loaded module [aggs-matrix-stats]
[2022-01-12T08:58:05,778][INFO ][o.e.p.PluginsService ] [support] loaded module [analysis-common]
[2022-01-12T08:58:05,778][INFO ][o.e.p.PluginsService ] [support] loaded module [constant-keyword]
[2022-01-12T08:58:05,778][INFO ][o.e.p.PluginsService ] [support] loaded module [frozen-indices]
[2022-01-12T08:58:05,778][INFO ][o.e.p.PluginsService ] [support] loaded module [ingest-common]
[2022-01-12T08:58:05,779][INFO ][o.e.p.PluginsService ] [support] loaded module [ingest-geoip]
[2022-01-12T08:58:05,779][INFO ][o.e.p.PluginsService ] [support] loaded module [ingest-user-agent]
[2022-01-12T08:58:05,779][INFO ][o.e.p.PluginsService ] [support] loaded module [kibana]
[2022-01-12T08:58:05,779][INFO ][o.e.p.PluginsService ] [support] loaded module [lang-expression]
[2022-01-12T08:58:05,780][INFO ][o.e.p.PluginsService ] [support] loaded module [lang-mustache]
[2022-01-12T08:58:05,780][INFO ][o.e.p.PluginsService ] [support] loaded module [lang-painless]
[2022-01-12T08:58:05,780][INFO ][o.e.p.PluginsService ] [support] loaded module [legacy-geo]
[2022-01-12T08:58:05,781][INFO ][o.e.p.PluginsService ] [support] loaded module [mapper-extras]
[2022-01-12T08:58:05,781][INFO ][o.e.p.PluginsService ] [support] loaded module [mapper-version]
[2022-01-12T08:58:05,781][INFO ][o.e.p.PluginsService ] [support] loaded module [parent-join]
[2022-01-12T08:58:05,781][INFO ][o.e.p.PluginsService ] [support] loaded module [percolator]
[2022-01-12T08:58:05,781][INFO ][o.e.p.PluginsService ] [support] loaded module [rank-eval]
[2022-01-12T08:58:05,782][INFO ][o.e.p.PluginsService ] [support] loaded module [reindex]
[2022-01-12T08:58:05,782][INFO ][o.e.p.PluginsService ] [support] loaded module [repositories-metering-api]
[2022-01-12T08:58:05,782][INFO ][o.e.p.PluginsService ] [support] loaded module [repository-encrypted]
[2022-01-12T08:58:05,782][INFO ][o.e.p.PluginsService ] [support] loaded module [repository-url]
[2022-01-12T08:58:05,782][INFO ][o.e.p.PluginsService ] [support] loaded module [runtime-fields-common]
[2022-01-12T08:58:05,783][INFO ][o.e.p.PluginsService ] [support] loaded module [search-business-rules]
[2022-01-12T08:58:05,783][INFO ][o.e.p.PluginsService ] [support] loaded module [searchable-snapshots]
[2022-01-12T08:58:05,783][INFO ][o.e.p.PluginsService ] [support] loaded module [snapshot-repo-test-kit]
[2022-01-12T08:58:05,783][INFO ][o.e.p.PluginsService ] [support] loaded module [spatial]
[2022-01-12T08:58:05,784][INFO ][o.e.p.PluginsService ] [support] loaded module [systemd]
[2022-01-12T08:58:05,784][INFO ][o.e.p.PluginsService ] [support] loaded module [transform]
[2022-01-12T08:58:05,784][INFO ][o.e.p.PluginsService ] [support] loaded module [transport-netty4]
[2022-01-12T08:58:05,785][INFO ][o.e.p.PluginsService ] [support] loaded module [unsigned-long]
[2022-01-12T08:58:05,785][INFO ][o.e.p.PluginsService ] [support] loaded module [vector-tile]
[2022-01-12T08:58:05,786][INFO ][o.e.p.PluginsService ] [support] loaded module [vectors]
[2022-01-12T08:58:05,786][INFO ][o.e.p.PluginsService ] [support] loaded module [wildcard]
[2022-01-12T08:58:05,786][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-aggregate-metric]
[2022-01-12T08:58:05,787][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-analytics]
[2022-01-12T08:58:05,787][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-async]
[2022-01-12T08:58:05,787][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-async-search]
[2022-01-12T08:58:05,788][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-autoscaling]
[2022-01-12T08:58:05,788][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-ccr]
[2022-01-12T08:58:05,788][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-core]
[2022-01-12T08:58:05,788][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-data-streams]
[2022-01-12T08:58:05,789][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-deprecation]
[2022-01-12T08:58:05,789][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-enrich]
[2022-01-12T08:58:05,789][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-eql]
[2022-01-12T08:58:05,789][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-fleet]
[2022-01-12T08:58:05,789][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-graph]
[2022-01-12T08:58:05,790][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-identity-provider]
[2022-01-12T08:58:05,790][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-ilm]
[2022-01-12T08:58:05,790][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-logstash]
[2022-01-12T08:58:05,790][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-ml]
[2022-01-12T08:58:05,790][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-monitoring]
[2022-01-12T08:58:05,791][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-ql]
[2022-01-12T08:58:05,791][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-rollup]
[2022-01-12T08:58:05,791][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-security]
[2022-01-12T08:58:05,792][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-shutdown]
[2022-01-12T08:58:05,792][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-sql]
[2022-01-12T08:58:05,792][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-stack]
[2022-01-12T08:58:05,792][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-text-structure]
[2022-01-12T08:58:05,793][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-voting-only-node]
[2022-01-12T08:58:05,793][INFO ][o.e.p.PluginsService ] [support] loaded module [x-pack-watcher]
[2022-01-12T08:58:05,793][INFO ][o.e.p.PluginsService ] [support] loaded plugin [ingest-attachment]
[2022-01-12T08:58:05,833][INFO ][o.e.e.NodeEnvironment ] [support] using [1] data paths, mounts [[/ (/dev/sda1)]], net usable_space [118.1gb], net total_space [150.1gb], types [ext4]
[2022-01-12T08:58:05,835][INFO ][o.e.e.NodeEnvironment ] [support] heap size [7.6gb], compressed ordinary object pointers [true]
[2022-01-12T08:58:05,884][INFO ][o.e.n.Node ] [support] node name [support], node ID [URIpYCQERq6d9T7sWphzpg], cluster name [elasticsearch], roles [transform, data_frozen, master, remote_cluster_client, data, ml, data_content, data_hot, data_warm, data_cold, ingest]
[2022-01-12T08:58:11,894][INFO ][o.e.x.m.p.l.CppLogMessageHandler] [support] [controller/3268] [Main.cc@122] controller (64 bit): Version 7.16.2 (Build 77e5cf03d1077d) Copyright (c) 2021 Elasticsearch BV
[2022-01-12T08:58:12,463][INFO ][o.e.x.s.a.s.FileRolesStore] [support] parsed [0] roles from file [/etc/elasticsearch/roles.yml]
[2022-01-12T08:58:13,810][INFO ][o.e.i.g.ConfigDatabases ] [support] initialized default databases [[GeoLite2-Country.mmdb, GeoLite2-City.mmdb, GeoLite2-ASN.mmdb]], config databases [[]] and watching [/etc/elasticsearch/ingest-geoip] for changes
[2022-01-12T08:58:13,812][INFO ][o.e.i.g.DatabaseNodeService] [support] initialized database registry, using geoip-databases directory [/tmp/elasticsearch-13626790051793039139/geoip-databases/URIpYCQERq6d9T7sWphzpg]
[2022-01-12T08:58:14,650][INFO ][o.e.t.NettyAllocator ] [support] creating NettyAllocator with the following configs: [name=elasticsearch_configured, chunk_size=1mb, suggested_max_allocation_size=1mb, factors={es.unsafe.use_netty_default_chunk_and_page_size=false, g1gc_enabled=true, g1gc_region_size=4mb}]
[2022-01-12T08:58:14,756][INFO ][o.e.d.DiscoveryModule ] [support] using discovery type [zen] and seed hosts providers [settings]
[2022-01-12T08:58:15,412][INFO ][o.e.g.DanglingIndicesState] [support] gateway.auto_import_dangling_indices is disabled, dangling indices will not be automatically detected or imported and must be managed manually
[2022-01-12T08:58:16,159][INFO ][o.e.n.Node ] [support] initialized
[2022-01-12T08:58:16,160][INFO ][o.e.n.Node ] [support] starting …
[2022-01-12T08:58:16,176][INFO ][o.e.x.s.c.f.PersistentCache] [support] persistent cache index loaded
[2022-01-12T08:58:16,177][INFO ][o.e.x.d.l.DeprecationIndexingComponent] [support] deprecation component started
[2022-01-12T08:58:16,294][INFO ][o.e.t.TransportService ] [support] publish_address {127.0.0.1:9300}, bound_addresses {127.0.0.1:9300}
[2022-01-12T08:58:16,350][ERROR][o.e.b.Bootstrap ] [support] Exception
java.lang.IllegalStateException: The index [zammad_production_user/XWWc8Fr8T72Dc4rqVm2tnw] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.16.2.
at org.elasticsearch.cluster.metadata.IndexMetadataVerifier.checkSupportedVersion(IndexMetadataVerifier.java:98) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.cluster.metadata.IndexMetadataVerifier.verifyIndexMetadata(IndexMetadataVerifier.java:80) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.gateway.GatewayMetaState.upgradeMetadata(GatewayMetaState.java:258) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.gateway.GatewayMetaState.upgradeMetadataForNode(GatewayMetaState.java:244) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.gateway.GatewayMetaState.start(GatewayMetaState.java:165) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.node.Node.start(Node.java:1185) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Bootstrap.start(Bootstrap.java:335) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:443) [elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:166) [elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:157) [elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:77) [elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:112) [elasticsearch-cli-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.Command.main(Command.java:77) [elasticsearch-cli-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:122) [elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:80) [elasticsearch-7.16.2.jar:7.16.2]
[2022-01-12T08:58:16,356][ERROR][o.e.b.ElasticsearchUncaughtExceptionHandler] [support] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: java.lang.IllegalStateException: The index [zammad_production_user/XWWc8Fr8T72Dc4rqVm2tnw] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.16.2.
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:170) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:157) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:77) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:112) ~[elasticsearch-cli-7.16.2.jar:7.16.2]
at org.elasticsearch.cli.Command.main(Command.java:77) ~[elasticsearch-cli-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:122) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:80) ~[elasticsearch-7.16.2.jar:7.16.2]
Caused by: java.lang.IllegalStateException: The index [zammad_production_user/XWWc8Fr8T72Dc4rqVm2tnw] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.16.2.
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:443) ~[elasticsearch-7.16.2.jar:7.16.2]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:166) ~[elasticsearch-7.16.2.jar:7.16.2]
… 6 more
[2022-01-12T08:58:16,371][INFO ][o.e.n.Node ] [support] stopping …
[2022-01-12T08:58:16,385][INFO ][o.e.n.Node ] [support] stopped
[2022-01-12T08:58:16,386][INFO ][o.e.n.Node ] [support] closing …
[2022-01-12T08:58:16,410][INFO ][o.e.n.Node ] [support] closed
[2022-01-12T08:58:16,413][INFO ][o.e.x.m.p.NativeController] [support] Native controller process has stopped - no new native processes can be started
Elasticsearch told that i have to reindex, but it don’t start so i can’t reindex.
ingest-attachment removed and installed new.
Hope anyone can help.
Zammad is running but we can not search or change the customer or anything else.
Thanks for help.
Martin
