Permission issue for customers in a shared organization
  • Used Zammad version: hosted
  • I would bring this up here - maybe someone does have a good solution. Support told me, this is normal behavior.
  • Hide article objects (like Title, State, Tags) on customers in shared organisations. Or better permission handling for customers in shared organisations. Customer permission should be the same for all customer tickets.
  • Customers which are in a shared organisation are able to see artikle objectes like Title,State,Tags etc. but not for their own tickets. Only for others in the same Organisation. It’s like an agent permission. So the customer could edit these objects like title, tag etc. At the moment we are able to hide some of these object with core workflows. But this is not possible for Tags. So it wouldn’t be good to use tags in our environment, as the customer could read all the informations.
  • Setup a shared organistation with multiple users.
  • Open tickets for different customers in the same organistation.
  • Login with a customers account or use the “view from users perspective”
  • Open the ticket for the other customer in the same organisation
I think we implement a problem with the last Major, I will check it.
Thanks for the report, we will handle it: Customer with shared organization has some unexpected fields visible when it's not the own ticket · Issue #5993 · zammad/zammad · GitHub
Should be fixed and available soon inside the packages.
Hi Dominik, thank you for taking care of it so quickly. When do you think it will be resolved in Zammad hosted?
Contact SaaS and request a manual pull of your instance. Use the issue link as argumentation. If you‘re super good, you also tell them when the update suits you (time corridor). Further questions shouldn‘t be needed then.
