- Used Zammad version: 5.0.3 (Channel Stable)
- Used Zammad installation type: (package via Ansible Role)
- Operating system: Ubuntu Server 20.04 LTS with CloudInit (Automatically installed via Terraform.)
- Browser + version: Mozilla Firefox 96.0.2 and Google Chrome 97.0.x (Windows NT 10.0; Win64; x64)
- Agents can work simultaneously without performance problems.
- When a certain number of agents (ca. 15) are connected to zammad, the system becomes very slow. Saving comments takes 20 to 60 seconds. After a reboot, the system responds very quickly until more users are working on the system again.
- Searching for tickets works very well even under load (ElasticSearch works without problems)
- The Production-Log or the Scheudluer-Log do not show any errors.
- The monitoring is always error-free.
- There are more than about 15 users working with the system.
Hardware
- Zammad is run on a virtualization cluster. (Proxmox)
Average resource consumption.
CPU: Average CPU utilization is 5%, under load it is 10%. Looking at the Ubuntu, the Zammad scheduler jumps between 5% and 100% (One Second Long) CPU utilization. (Cluster has 48 x Intel(R) Xeon(R) CPU E5-2697 v2)
RAM: More RAM does not bring any improvement. ElasticSearch uses a MemoryLock so that nothing goes into the SWAP.
Storage: 40 GB (Data Center SSDs - Samsung SM883 - 540 MB/s Read and 520 MB/s Write)
Switching from HDD storage pool to SSD has brought a 30% speed advantage when saving replies / comments under load. -
Tested with the following hardware settings:
15 CPUs and 24 GB RAM
It did not bring any improvement.
State when the problem occurred:
zammad run rails r "p User.joins(roles: :permissions).where(roles: { active: true }, permissions: { name: 'ticket.agent', active: true }).uniq.count"
72
zammad run rails r "p Sessions.list.count"
41
zammad run rails r "p User.count"
529
zammad run rails r "p Overview.count"
46
zammad run rails r "p Group.count"
15
zammad run rails r 'p Delayed::Job.count'
0
zammad run rails r 'p Delayed::Job.first'
nil
Our configuration of Zammad:
The recommendations from the Zammad documentation were used.
Elasticsearch:
es_version: 7.16.3
es_heap_size: 4gb
es_plugins: ingest-attachment
es_config:
node.name: "zammad_es"
http.host: localhost
http.port: 9200
http.max_content_length: 400mb
indices.query.bool.max_clause_count: 2000
bootstrap.memory_lock: true
Postgres:
postgresql_hba_entries:
- { type: local, database: all, user: postgres, auth_method: trust }
- { type: local, database: all, user: all, auth_method: trust }
- { type: host, database: all, user: all, address: '127.0.0.1/32', auth_method: md5 }
- { type: host, database: all, user: all, address: '::1/128', auth_method: md5 }
postgresql_global_config_options:
- option: unix_socket_directories
value: '/var/run/postgresql'
- option: max_connections
value: 2000
- option: shared_buffers
value: '2GB'
- option: temp_buffers
value: '256MB'
- option: work_mem
value: '10MB'
- option: max_stack_depth
value: '5MB'
I think the bottleneck is the Postgres database, but the available resources are not being used. Can you help me with this problem?
Unfortunately, this problem was not noticed on the test system.
Best regards
Patrick
