I just tested pending reminder by setting pending state for 03:40 pm and the notification was triggered around 03:52 pm. Do you have any history entries regarding the pending reminder?
what’s your timezone?
there was a timezone bug that affected pending reminders, I don’t know if it’s fixed. I’m in +10, if I set a pending reminder before 10am the date would get decremented, lets say it’s 1pm and I set a pending reminder for tomorrow at 9am, the date stored in the reminder would be for today at 9am, which is in the past, so will never trigger.
I guess you’re right, we’re in Berlin (UTC+2). But the reminders do not match the timezone difference:
At 13:35 I set the reminder to 13:45 (which is 11:45 UTC for the system)
- 07/09/2018 13:35
updated Ticket pending_time from '2018-09-07 11:15:00 UTC' to '2018-09-07 11:45:00 UTC'
- 08/09/2018 02:02
notification sent to 'user@example.com(reminder_reached:online,email)'
- 09/09/2018 02:03
- 10/09/2018 02:07
It’s not even a shift in full hours, which I would expect here. Does anyone have an idea what happens here?
oh right, it’s 13:35 and it set the reminder to 11:15.
my guess is they set the reminder to 2018-09-08 11:15 and it decremented the date, it doesn’t look like the notifications sent lines are related?
I would create an issue at https://github.com/zammad/zammad/issues I kind of did but too with https://github.com/zammad/zammad/issues/2085 but i mentioned a few different timezone issues and I think they are separate issues and should be in a separate issue report, I don’t know if pending reminders use elasticsearch at all, which my issue morphed into.
Pending reminders shouldn’t be affected by timezone issues, as I use them every day, this works.
It may happen that delays up to 10 mins come as effect.
I’d love to know how many delayed jobs you have. Your pending reminders are way off, I know of no other Zammad-Installation doing that!
You can that information by running the following on your zammad-installation:
Is it intended behaviour that consecutive pending reminder notifications are always triggered at around 02:00 am the following days? I would have expected them to keep the configured pending reminder time as trigger.
I just set up more test tickets to see how Zammad reacts to them. All created today, one with reminder today, one for tomorrow morning and one for the afternoon.
it doesn’t work for me. What is your timezone? I guess it’s a low digit, maybe +2 as well. Try setting a pending reminder for tomorrow at 1am. Or try setting your timezone (desktop I guess, not server) to a high number like +10, then set a pending reminder for 9am tomorrow. If it is a timezone issue you wouldn’t see if your timezone is +2 and you set pending reminders after 2am.
But spicewiesel’s issue might not be related to timezones, or maybe my issue isn’t related to timezones either, but I do have an issue with pending reminders.
