Pause / Stop channel fetching during enabled maintenance
Title: Stop communications with enabled maintenance mode
    Enabling maintenance mode has only an affect on non administrative sessions, however, if you want to restructure Zammad and have a fair amount of email channels, you’d have to disable all channels to achieve a “communication silence” to re-configure your system structure, groups and routings in piece.
    The maintenance mode sounds like it does more (than it does and that’s advertised) as a maintenance usually means that you don’t want data to be changed - not just from agent perspective.
    The maintenance mode only kicks off non administrative sessions.
    Maintenance mode should (optionally?) also disable communication channels to allow actual data and routing maintenances without changing productive data in Zammad. (This allows you to fuck up a configuration and take a snapshot to restore - that’s not possible if communication data is being changed).
Your Zammad environment:
  • Average concurrent agent count: 10
  • Average tickets a day: 200
  • What roles/people are involved: Admins, Agents, Customers
I like the suggestion, it saves a lot of clicking.
It also prevents you from forgetting to switch on the email channels afterwards.
Title: Maintenance mode - auto disable channels
    While doing updates / making changes in maintenance mode sometimes rollbacks are needed.
    I would like to have all channels disabled so that no new tickets come in that might accidentally get lost in a rollback.
    It is definitely doable to disable the channels manually each, but having it all rolled into an on-off switch in the maintenance mode.
    A one stop shop for locking down communication in and out of zammad until maintenance mode is disabled.
  • Average concurrent agent count: 4
  • Average tickets a day: 30 - 60 depending on the time of year.
  • What roles/people are involved: tech / teachers & faculty
Thank you and have fun.
