Overview / updates not pushed to client
  • Used Zammad version :
    6.1.0
  • Used Zammad installation type : (source, package, docker-compose, …)
    Zammad Helm v10.0.2 @ Azure Kubernetes Service 1.25.6
  • Operating system :
    Helm chart defaults
  • Browser + version :
    Chromium 118.0.5993.88
    Tried on different browsers (Safari, Firefox, etc.)
Expected behavior :
  • Normally, when new tickets are created through e-mail, they pulled from the channel and the browser view should update automatically the tickets list and counts in Overview Pane.
Actual behavior :
  • There is no update of the view and users need to refresh (F5) their browser to see updates
More details :
  • Webservice seems to be operational as there are events transiting through the socket :
  • Scheduler container uses about 10% CPU
  • All schedulers seem active : rails r “p Scheduler.pluck(:name, :active)”
  • There is no explicit failure or error in all containers logs
  • WS tested directly seems to be operational
  • TMP directory on the scheduler / railsserver
  • rails r “p Delayed::Job.count” is equal to 0
  • redis seems operational and contains session data
Situation
This is a very sad situation and I am running out of options after having spent hours and hours digging in the forum, documentation and Google.
I kindly ask for you whatever suggestion or help you can provide.
Thank you very much for your dedication and this nice community software that you have !
Radu Stoichita
Maybe the job for it failed. Check your Admin → Monitoring (#system/monitoring) and restart failed jobs if there are some. There will be a Restart failed jobs button if something is wrong with it.
Hi, thanks you very much for the suggestion but unfortunately it says all good :slight_smile:
Shouldn’t failed jobs restart automatically after some time ?
Also there is no logs in DevTools console :
