"Outgoing Call" Ticket is automatically set to state open
  • Used Zammad version: 5.2.1
  • Operating system: ubuntu
  • Browser + version: chrome
  • If you create a ticket of type “outgoing call” via the web interface and set the status to “new”, then the status of the ticket should be “new”.
  • The status is changed from “new” to “open” according to the history directly after the creation.
  • see above
Further stuff
  • I don’t know if it’s a bug, or intentional. Because logically you have already started working on something when you have an outgoing call. However, it is then strange that you can select “new” under status at all.
That’s intentional because your agent already started working on the ticket.
