- Used Zammad version: 2.8.0
- Used Zammad installation source: (source, package, …): package rpm
- Operating system: OpenSuse 42.3
- Browser + version: Chrome 71
- import runs through all tickets in old OTRS 3.3.7 System (roughly 100k Tickets)
- Import fails ~1500 Tickets with Error. (Console Exits)
Until then the log looks fine to me… see below as example
thread#1: Ticket 98651, Article 465361 - Starting import for fingerprint f347f314d9a38ad7c56831ad7dca41829229ae82ca3b84ed8542b1a6b869c779 (file-2)… Queue: [1].
I, [2019-01-03T09:41:03.464027 #2885-47276350211760] INFO – : thread#4: add Ticket::Article.find_by(id: 463551)
I, [2019-01-03T09:41:03.466138 #2885-47276350215520] INFO – : thread#1: Ticket 98651, Article 465361 - Finished import for fingerprint f347f314d9a38ad7c56831ad7dca41829229ae82ca3b84ed8542b1a6b869c779 (file-2)… Queue: [1].
I, [2019-01-03T09:41:03.472511 #2885-47276350214820] INFO – : thread#2: Ticket 98796, Article 467619 - Starting import for fingerprint a3c7e83f85dfa0205d3980ca891ef82df9516999832c7fb0755e367168b9e347 (file-2)… Queue: [2].
I, [2019-01-03T09:41:03.473202 #2885-47276354371000] INFO – : thread#7: Ticket 98692, Article 463828 - Starting import for fingerprint ae6153a62144b9a7e9c8ec5f2b47e0bd7f30618e63665450835f605469cc92b3 (gwcheck.log)… Queue: [7].
I, [2019-01-03T09:41:03.485548 #2885-47276350215520] INFO – : thread#1: add Ticket::Article.find_by(id: 465384)
the following error is produced on the console when it exits (only thread 5 posted)
> thread#5: POST: http://helpdesk.xxxx.com/otrs/public.pl?Action=ZammadMigrator
> thread#5: PARAMS: {:Subaction=>"Export", :Object=>"Ticket", :Limit=>20, :Offset=>1200, :Diff=>0, :Action=>"ZammadMigrator", :Key=>"XXXXX"}
> thread#5: ERROR: Server Error: #<Net::HTTPInternalServerError 500 Internal Server Error readbody=true>!
> /opt/zammad/lib/import/otrs/requester.rb:132:in `post': Zammad Migrator returned an error (RuntimeError)
> from /opt/zammad/lib/import/otrs/requester.rb:92:in `request_json'
> from /opt/zammad/lib/import/otrs/requester.rb:79:in `request_result'
> from /opt/zammad/lib/import/otrs/requester.rb:34:in `load'
> from /opt/zammad/lib/import/otrs.rb:143:in `import_action'
> from /opt/zammad/lib/import/otrs.rb:137:in `imported?'
> from /opt/zammad/lib/import/otrs.rb:101:in `block (3 levels) in threaded_import'
> from /opt/zammad/lib/import/otrs.rb:95:in `loop'
> from /opt/zammad/lib/import/otrs.rb:95:in `block (2 levels) in threaded_import'
> from /opt/zammad/vendor/bundle/ruby/2.4.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
on the apache error log of the OTRS machine I can see the following JSON Error: It happens exactly 6 times and with the 6th time it exits. (Timestamps of log above and below do not match but same errors appear, i just had the logs from the 2nd run handy and purged before)
> [Thu Jan 03 11:47:00 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x89\n \nGr], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
> [Thu Jan 03 11:47:30 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x89\n \nGr], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
> [Thu Jan 03 11:48:15 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x89\n \nGr], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
> [Thu Jan 03 11:53:26 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x8a. Du], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
> [Thu Jan 03 11:53:56 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x8a. Du], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
> [Thu Jan 03 11:54:41 2019] [error] malformed or illegal unicode character in string [\xed\xa0\xbd\xed\xb8\x8a. Du], cannot convert to JSON at /opt/otrs/Kernel/cpan-lib/JSON.pm line 154.\n
- setup fresh Zammad
- Install OTRS migrator for 3.3
- manual import from console with
zammad run rails c Setting.set('import_otrs_endpoint', 'http://helpdesk.xxxx.com/otrs/public.pl?Action=ZammadMigrator') Setting.set('import_otrs_endpoint_key', 'XXXXXXX') Setting.set('import_mode', true) Import::OTRS.start
Any idea how to identify which tickets contain the supposed malformed unicode characters in OTRS or how to escape them properly during import?
Thanks Alex
