Organization Objects Side By Side
  • Used Zammad version: 6.3.1-1720156707.17f20fad.centos9
  • Operating system: Oracle Linux 9
  • Browser + version: Firefox 127.0 (64-bit)
  • I created custom fields for organizations and would like to place them side by side.
  • Go to Object Manager
  • Click on Organization
  • Create the custom field, try organize by Position. (Try put the same position for 2 objects)
  • Go to Organizations and try organize.
Hi @QuintelaCarvalho. This is not possible via GUI.
what are the possibilities?
Via GUI? None, as already mentioned. You can play around with it by checking the code and using the Rails Console and related commands.
Thanks for the explanation. I’m not a dev, but i’ll try :smile:
