Hello Zammad Community,
We are currently facing the requirement to assign different sender email addresses to an organization.
The organization is named “Examplecompanyname” is set up as a domain-based allocation with the email domain @Examplecompanyname.com
We want email addresses from, for example, Examplecompanyname**.at** to also be assigned to the organization “Examplecompanyname” so that a trigger which is configured will be triggered.
We previously set up a workaround for this by adding an object/field named “Parent Company” to organizations in our Zammad instance. We set up the different organizations along with their respective email domains and parent company assignment, and changed the trigger to the “parent company” Attribute. This works very well in principle, but the only disadvantage is that we have to add each organization and email domain individually.
The goal is that Zammad will do this automatically if configured.
I appreciate any feedback and thank you all in advance
Best Maximilian
Please use the mandatory template for this category.
Also, your request smells like a duplicate. Please run a search in the feature request category to see if that’s actually the case and give your heart to the first article of the relevant thread. Please also let us know so we can merge accordingly.
Hello MrGeneration,
thanks for your approval!
I did not find a topic which described the same issue/request yet.
Similar yes but not a ccTLD Wildcard Function to auto assign or create new organizations by filling out an individiual field in a zammad instance.
Best
Thanks. I guess my mind played tricks on me.
Could you please edit your first post to reflect this tempalte?
It is fine if you answer several bullet points with one block if you’d other wise repeat yourself over and over again!
Your Zammad environment:
* Average concurrent agent count:
* Average tickets a day:
* What roles/people are involved:
