OpenID Connect - maybe wrong token endpoint auth method for public OIDC client sent
  • Used Zammad version: 7.0.1
  • Operating system: Ubuntu 24.04 LTS host system + Docker
  • Browser + version: Safari 26.4, Firefox 149.0.2
  • Login via third party OpenID Connect Authentication to Zammad
At our university, we have a Shibboleth IDP with an activated OpenID Connect Provider module on top, see de:shibidp:config-extensions-oidc [Dokumentation DFN-AAI, DFN-PKI und eduroam].
Using the OpenID Connect Provider to authenticate against other services, like BBB, works fine. Here we use a client secret that is configured in the BBB instance.
Zammad, on the other hand, seems to be a public client, so no client secret can be specified. Currently, we do not have the ability to authenticate against our OpenID Connect IDP.
Our employee responsible for our IDP told me that Zammad uses the wrong token endpoint authentication method. He indicated that Zammad sends token_endpoint_auth_method = client_secret_basic instead of token_endpoint_auth_method = none.
Is there a way to configure this within Zammad?
Or is there another university which has a working example?
  1. Enable third-party registration via OpenID Connect in the Zammad UI.
  2. Set the identifier and the URL of the IDP.
  3. Set the UID field to sub, scopes to openid email profile and PKCE to yes.
  4. Try to authenticate.
Thanks.
The current implementation works only via the discovery endpoint.
I think this PR is maybe related, but currently we have no priority working on that, it has not a state that we can merge it directly, we would need so spent some more time.
We have the same problem. Newer version of OIDC don’t work well with Discovery endpoint. We get the message : invalid_client
What’s the client_secret we can use then ??? at our idp site ?
