OAuth 2 answers with 404 Error "Not found"
  • Used Zammad version: 2.5
  • Operating system: CentOS 7
  • Response with list of users
  • 404 Not found
I have set up an api connection using OAuth 2 Token. If the token would not be valid, it would response with an error 401 “Unauthorized”. The token is valid. However, I get an error 404.
If I use the same call with Basic Authentication via username and password or via a personal token, then it works fine.
Has someone any idea how this can happen or what I can do to check?
Thanks,
Gijs
