Hello
I have noticed that the volume of notification sounds can be quite loud compared to other web apps, and it would be nice if agents could adjust the volume of notifications themselves.
A simple slider below the notification sound settings would probably suffice.
Created a pull request with this functionality:
zammad:develop ← Stubenhocker1399:notification-sound-volume
opened 03:29PM - 28 May 22 UTC
Hello! :wave:
I added a volume slider for notifications as described in this… [community post](https://community.zammad.org/t/notification-volume-slider/9061).
It uses the personal localStorge as different agents might have different audio volume preferences depending on which device they are using.
(Just a note: The PR creation template asked me to run coffeelint, however you've removed this gem in https://github.com/zammad/zammad/commit/6fbdb3ca2abca5e937a3b19701218259254665a8, is this still expected to be run?
Running `coffeelint.rb coffeelint.json -r src/` manually at least seemed to have caused no complaints for this change. :smile: )
As the PR got closed, as an alternative there are browser extensions which one can use instead:
Up to 600% volume boost
For Firefox there too seem to be some, but I haven’t tested any of them.
Is there at least a possibility to choose “no sound” instead of “Xylo”? While using a soft phone the notification sounds are annoying.
Have a look into the settings. Please don’t hijjack feature requests with your technical questions.
system
Closed
June 4, 2023, 3:07am
6
