- Used Zammad version: zammad-6.0.0-1691402172.2296ccd0.centos8.x86_64
- Operating system: Almalinux 8.8
- Browser + version: Chromium Version 115.0.5790.110
- Install package without any error via package manager after installing ElasticSearch
- Error:
Problem: cannot install the best candidate for the job- nothing provides elasticsearch needed by zammad-6.0.0-1691402172.2296ccd0.centos8.x86_64
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
- Setup a fresh and updated server
# install postgres
> dnf install postgresql-server
> /usr/bin/postgresql-setup --initdb
> systemctl enable --now postgresql.service
# install java
> dnf install java-11-openjdk
# install ElasticSearch
> dnf install elasticsearch-oss
> curl http://127.0.0.1:9200
"name" : "de-sd-01",
"cluster_name" : "elasticsearch",
"cluster_uuid" : "bXwXFtONQIeOAFaAWR4KSw",
"version" : {
"number" : "7.10.2",
"build_flavor" : "oss",
"build_type" : "rpm",
"build_hash" : "747e1cc71def077253878a59143c1f785afa92b9",
"build_date" : "2021-01-13T00:42:12.435326Z",
"build_snapshot" : false,
"lucene_version" : "8.7.0",
"minimum_wire_compatibility_version" : "6.8.0",
"minimum_index_compatibility_version" : "6.0.0-beta1"
"tagline" : "You Know, for Search"
# install Zammad
> rpm --import https://dl.packager.io/srv/zammad/zammad/key
> wget -O /etc/yum.repos.d/zammad.repo \
https://dl.packager.io/srv/zammad/zammad/stable/installer/el/8.repo
> dnf install zammad
I’ve tried to reboot without any luck.
Could it be that the RPM build has an dependency issue or am I doing it wrong?
