Used Zammad version: 5.4.0
Used Zammad installation type:package
Operating system: ubuntu
Browser + version: chrome
Hi! when I try to copy and paste some information in field NOTE when I add new customer I can’t do that. Only typing by hand is working. Can you please make this field to be able get the information using CTRL + V
The same problem. Zammad 5.4.1
I think it is the same bug like this:
opened 09:07AM - 20 Mar 23 UTC
bug
verified
### Used Zammad Version
5.3 & 5.4
### Environment
- Installation method: pack… age
- Operating system (if you're unsure: `cat /etc/os-release` ): Debian 10
- Database + version: postgresql 11.19
- Elasticsearch version: 7.17.9
- Browser + version: Chrome 10x, Edge
### Actual behaviour
When creating a new organization, it is not possible, to paste text into the note field. Nether with context menu entry, nor with Strg-V, nor Shift-Insert.
### Expected behaviour
The text should be pasted in the note field. Other field on the creation mask are working. In Zammad 5.2 it was also working.
### Steps to reproduce the behaviour
Copy some text to the clipboard, create a new organization an paste the Text into the note field. Nothing happens.
### Support Ticket
_No response_
### I'm sure this is a bug and no feature request or a general question.
yes
