Same issue here on a fresh rpm installation with latest Zammad release (CentOS 7). Users are listed only when elasticsearch is disabled with
zammad run rails r "Setting.set('es_url', '')"
I opened up a new issue on github but it was closed with following message:
This is not an issue but a technical question. You can ask questions over at https://community.zammad.org/ - Closing now.
However, it looks like the attachment plugin is missing.
But ingest-attachment has been installed as I followed the docs https://docs.zammad.org/en/latest/install-elasticsearch.html#centos-7
Edit:
error in /var/log/elasticsearch/elasticsearch.log
[2018-08-22T13:52:42,381][DEBUG][o.e.a.b.TransportBulkAction] [F4C9LDY] failed to execute pipeline [zammad585996485883] for document [zammad_production/User/4]
java.lang.IllegalArgumentException: pipeline with id [zammad585996485883] does not exist
at org.elasticsearch.ingest.PipelineExecutionService.getPipeline(PipelineExecutionService.java:194) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.ingest.PipelineExecutionService.access$100(PipelineExecutionService.java:41) ~[elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.ingest.PipelineExecutionService$2.doRun(PipelineExecutionService.java:88) [elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:674) [elasticsearch-5.6.10.jar:5.6.10]
at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:37) [elasticsearch-5.6.10.jar:5.6.10]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_181]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
Edit2:
exception when trying to rebuild searchindex
[root@zammad ~]# zammad run rake searchindex:rebuild
drop indexes...done
create indexes...done
create pipeline (pipeline)... rake aborted!
Unable to process PUT request to elasticsearch URL 'http://127.0.0.1:9200/_ingest/pipeline/zammad585996485883'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00005651117e7580 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"header\":{\"processor_type\":\"foreach\"}}],\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"header\":{\"processor_type\":\"foreach\"}},\"status\":400}", @data=nil, @code="400", @content_type=nil, @error="Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!">
Payload:
{:description=>"Extract zammad-attachment information from arrays", :processors=>[{:foreach=>{:field=>"article", :ignore_failure=>true, :processor=>{:foreach=>{:field=>"_ingest._value.attachment", :ignore_failure=>true, :processor=>{:attachment=>{:target_field=>"_ingest._value", :field=>"_ingest._value._content", :ignore_failure=>true}}}}}}]}
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:113:in `block (2 levels) in processors'
/opt/zammad/lib/search_index_backend.rb:73:in `each'
/opt/zammad/lib/search_index_backend.rb:73:in `block in processors'
/opt/zammad/lib/search_index_backend.rb:70:in `each'
/opt/zammad/lib/search_index_backend.rb:70:in `processors'
/opt/zammad/lib/tasks/search_index_es.rake:66:in `block (2 levels) in <top (required)>'
/opt/zammad/lib/tasks/search_index_es.rake:46:in `block (2 levels) in <top (required)>'
/opt/zammad/lib/tasks/search_index_es.rake:142:in `block (2 levels) in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.1/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli.rb:360:in `exec'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor.rb:369:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli.rb:20:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/base.rb:444:in `start'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/cli.rb:10:in `start'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/lib/bundler/friendly_errors.rb:121:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.2/exe/bundle:22:in `<top (required)>'
