NGINX Reverse Proxy for HTTPS
What may be the correct Config for a NGINX as reverseproxy for Zammad? I have config, wich allows me to open the Webfrontend, but the Chat is not working.
server {
        listen 80 default_server;
        listen [::]:80 default_server;
        server_name _;
server {
        listen 443 ssl;
        server_name helpdesk2.ebel.local;
        server_name helpdesk.ebel.local;
        error_log  /var/log/nginx/helpdesk-error.log;
        access_log /var/log/nginx/helpdesk-access.log;
        ssl_certificate /etc/ssl/certs/helpdesk.ebel.local.pem;
        ssl_certificate_key /etc/ssl/private/helpdesk2.ebel.local.key.pem;
        include /etc/ssl/options-ssl-nginx.conf;
        ssl_dhparam /etc/ssl/certs/dhparam.pem;
        ssl_verify_client off;
        # Set global proxy settings
        proxy_read_timeout      360;
        client_max_body_size 50M;
                expires max;
        location /ws {
                proxy_http_version 1.1;
                proxy_pass http://172.30.0.35;
        location / {
                proxy_pass http://172.30.0.35:8080;
                gzip on;
                gzip_proxied any;
I guess the reason why the chat doesnt work, is because a wrong reverse Proxy config.
You’re using zammad-docker-compose? 172.30.0.35 is the IP of the host, and 8080 is the exposed port of the zammad-nginx container? In that case I’d say the configuration for /ws is wrong - it should probably point to port 8080 too.
You can use the browser debug console -> network to figure out whether Zammad can connect to the websocket. There should be a successful request to /ws after pressing F5, and there should be transmitted frames in there.
This is how I’ve configured Apache on our server for that purpose:
zammad.ourcompany.tld ~ # cat /root/zammad-docker-compose/docker-compose.override.yml
version: '2'
services:
  zammad-nginx:
    ports:
      - "8080:80"
zammad.ourcompany.tld ~ # cat /etc/apache2/sites-enabled/zammad-https.conf
<IfModule mod_ssl.c>
    <VirtualHost _default_:443>
        ServerAdmin webmaster@localhost
        ServerName zammad.ourcompany.tld
        # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
        # error, crit, alert, emerg.
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        # Zammad
        # https://github.com/zammad/zammad/blob/develop/contrib/apache2/zammad.conf
        <Location />
            ProxyPass http://localhost:8080/
            ProxyPassReverse http://localhost:8080/
        </Location>
        <Location /ws>
            ProxyPass ws://localhost:8080/ws
            ProxyPassReverse ws://localhost:8080/ws
        </Location>
