NGINX and Lets´s Encrypt fail
  • Used Zammad version: newest
  • Browser + version: Chrome
If I use the command:
sudo certbot certonly --webroot -w /var/www/html -d support.*ZENSOR*.de --cert-path /path/to/ssl/certificate --key-path /path/to/ssl/certificate_key
then the error comes:
aving debug log to /var/log/letsencrypt/letsencrypt.log
Requesting a certificate for support.*ZENSOR*.de
Certbot failed to authenticate some domains (authenticator: webroot). The Certificate Authority reported these problems:
  Domain: support.*ZENSOR*.de
  Type:   connection
  Detail: *ZENSOR*: Fetching http://support.*ZENSOR*.de/.well-known/acme-challenge/obDuWniY576ruiUsZHPcNT6mnS0nyiJTb1AkQpr2yZA: Connection refused
Hint: The Certificate Authority failed to download the temporary challenge files created by Certbot. Ensure that the listed domains serve their content from the provided --webroot-path/-w and that files created there can be downloaded from the internet.
Some challenges have failed.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
And if i want to start nginx there is this Error:
nginx.service - A high performance web server and a reverse proxy server
     Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Mon 2023-06-26 18:00:18 UTC; 35s ago
       Docs: man:nginx(8)
    Process: 1809 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
        CPU: 1ms
Jun 26 18:00:18 Zammad systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 26 18:00:18 Zammad nginx[1809]: nginx: [emerg] "server" directive is not allowed here in /etc/nginx/nginx.conf:1
Jun 26 18:00:18 Zammad nginx[1809]: nginx: configuration file /etc/nginx/nginx.conf test failed
Jun 26 18:00:18 Zammad systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Jun 26 18:00:18 Zammad systemd[1]: nginx.service: Failed with result 'exit-code'.
Jun 26 18:00:18 Zammad systemd[1]: Failed to start A high performance web server and a reverse proxy server.
The Configuration from NGINX is:
server {
    listen 80;
    zammad.*ZENSOR*.de;
server {
    listen 443 ssl http2;
   zammad.*ZENSOR*.de;
    ssl_certificate /path/to/ssl/certificate;
    ssl_certificate_key /path/to/ssl/certificate_key;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_ciphers 'TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384';
    client_max_body_size 50M;
    location /ws {
        proxy_http_version 1.1;
        proxy_read_timeout 86400;
    location / {
        proxy_read_timeout 300;
I’ve already looked through the other threads and haven’t found one that fits. If I have missed one, just send the link.
Thanks in advance for any help
Hi @SoulTrapX, I didn’t have much time right now, therefore just a small hint:
In your NGINX configuration, in front of zammad.*ZENSOR*.de, server_name is missing.
In general, you should have a look in here: zammad/contrib/nginx/zammad_ssl.conf at stable · zammad/zammad · GitHub
Thanks for your time, I have now adjusted the config file, this now looks like this:
upstream zammad-railsserver {
  server 127.0.0.1:3000;
upstream zammad-websocket {
  server 127.0.0.1:6042;
server {
  listen 80;
  listen [::]:80;
  server_name support.*ZENSOR*.de;
  server_tokens off;
  location /.well-known/ {
    root /var/www/html;
  return 301 https://$server_name$request_uri;
server {
  listen [::]:443 ssl http2;
  server_name support.*ZENSOR.de;
  server_tokens off;
  ssl_certificate /etc/nginx/ssl/support.*ZENSOR*.pem;
  ssl_certificate_key /etc/nginx/ssl/support.*ZENSOR*.pem;
  ssl_protocols TLSv1.2;
  ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
  ssl_dhparam /etc/nginx/ssl/dhparam.pem;
  ssl_prefer_server_ciphers on;
  ssl_session_timeout 180m;
  ssl_stapling on;
  ssl_stapling_verify on;
  ssl_trusted_certificate /etc/nginx/ssl/lets-encrypt-x3-cross-signed.pem;
  resolver 8.8.8.8 8.8.4.4;
  add_header Strict-Transport-Security "max-age=31536000" always;
  location = /robots.txt  {
    access_log off; log_not_found off;
  location = /favicon.ico {
  root /opt/zammad/public;
    expires max;
  # legacy web socket server
  location /ws {
  # action cable
  location /cable {
  location / {
    proxy_set_header X-Forwarded-Proto	$scheme;
    proxy_read_timeout 180;
    gzip on;
    gzip_proxied any;
But now I still have this error:
     Active: failed (Result: exit-code) since Mon 2023-06-26 18:48:58 UTC; 5s ago
       Docs: man:nginx(8)
    Process: 1309 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
        CPU: 1ms
Jun 26 18:48:58 Zammad systemd[1]: Starting A high performance web server and a reverse proxy server...
Jun 26 18:48:58 Zammad nginx[1309]: nginx: [emerg] "upstream" directive is not allowed here in /etc/nginx/nginx.conf:1
Jun 26 18:48:58 Zammad nginx[1309]: nginx: configuration file /etc/nginx/nginx.conf test failed
Jun 26 18:48:58 Zammad systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE
Jun 26 18:48:58 Zammad systemd[1]: nginx.service: Failed with result 'exit-code'.
Jun 26 18:48:58 Zammad systemd[1]: Failed to start A high performance web server and a reverse proxy server.
I guess you should read some nginx docs :slight_smile:
Btw: Your conf file for Zammad should be here: /etc/nginx/sites-available/zammad.conf
