New M365 Channel using GraphAPI instead of IMAP/SMTP
    Microsoft 365 provides access to their mailboxes using IMAP/SMTP+OAuth or their GraphAPI interface directly. The GraphAPI approach has several benefits for users with Microsoft 365 mailboxes:
  • No need to manually configure Zammad as an app in the Azure Portal
  • It still can be used when IMAP/SMTP is disabled tenant-wide
  • It is faster
  1. Which are one or two concrete situations where this problem hurts the most?
    Our service provider decided to disable IMAP/SMTP support for whatever reason.
  2. Why is it not solvable with the Zammad standard?
    Because Zammad persist on IMAP/SMTP at the moment.
  3. What is your expectation/what do you want to achieve?
    Being able to use GraphAPI for e-mail fetching and sending.
I just want to make sure that you know this is highly requested!
Not only does that have the positive effects you provided in the post, it will also save costs, as it will anymore be a requirement to give each shared mailbox a license.
