- Used Zammad version: 4.1.x
- Operating system: Ubuntu 16.04.7
- Browser + version: Chrome 92.0.4515.131
Zammad should load overview data (tickets)
Zammad doesn’t load any overview data (tickets) and gives 500 server error. Logs show various MySQL errors:
Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock'
Lost connection to MySQL server during query
MySQL server has gone away
Can't reconnect to database
None
Zammad stopped working after a power outage caused the server it runs on to ungracefully shut down.
All the errors seem to be related to Zammad not being able to complete any MySQL requests:
E, [2021-09-08T09:34:03.726287 #18625-47116445214100] ERROR -- : thread_client 47322444742460 exited with error #<ActiveRecord::StatementInvalid: Mysql2::Error: Lost connection to MySQL server during query: SELECT `activity_streams`.* FROM `activity_streams` WHERE ((permission_id IN (35,37,40,41,42,45,50,55) AND (group_id IS NULL OR group_id IN (4))) OR (permission_id IS NULL AND group_id IN (4))) ORDER BY `activity_streams`.`created_at` DESC LIMIT 1>
E, [2021-09-08T09:34:03.726362 #18625-47116445214100] ERROR -- : /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query'
E, [2021-09-08T09:34:03.726596 #18716-46957983579280] ERROR -- : Mysql2::Error: Lost connection to MySQL server during query: SELECT `users`.* FROM `users` WHERE `users`.`id` = 19225 LIMIT 1 (ActiveRecord::StatementInvalid)
E, [2021-09-08T09:34:03.727081 #18625-47116437931440] ERROR -- : thread_client 47322444927080 exited with error #<ActiveRecord::StatementInvalid: Mysql2::Error: Lost connection to MySQL server during query: SELECT `users`.* FROM `users` WHERE `users`.`id` = 19225 LIMIT 1>
E, [2021-09-08T09:34:03.727146 #18625-47116437931440] ERROR -- : /opt/zammad/vendor/bundle/ruby/2.6.0/gems/mysql2-0.4.10/lib/mysql2/client.rb:120:in `_query'
E, [2021-09-08T09:34:03.727218 #18716-46957983571380] ERROR -- : Mysql2::Error: Lost connection to MySQL server during query: SELECT `users`.* FROM `users` WHERE `users`.`id` = 19225 LIMIT 1 (ActiveRecord::StatementInvalid)
I, [2021-09-08T09:34:03.728792 #18716-46957983571380] INFO -- : Completed 500 Internal Server Error in 98122ms (ActiveRecord: 97618.2ms)
F, [2021-09-08T09:34:03.729292 #18716-46957983571380] FATAL -- :
F, [2021-09-08T09:34:03.730021 #18716-46957983571380] FATAL -- : ActiveRecord::StatementInvalid (Mysql2::Error: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2): SELECT 1 AS one FROM `permissions` INNER JOIN `permissions_roles` ON `permissions`.`id` = `permissions_roles`.`permission_id` INNER JOIN `roles` ON `permissions_roles`.`role_id` = `roles`.`id` INNER JOIN `roles_users` ON `roles`.`id` = `roles_users`.`role_id` WHERE `roles_users`.`user_id` = 3 AND `roles`.`active` = TRUE AND `permissions`.`active` = TRUE AND `permissions`.`name` = 'admin' LIMIT 1):
F, [2021-09-08T09:34:03.730324 #18716-46957983571380] FATAL -- :
F, [2021-09-08T09:34:03.730365 #18716-46957983571380] FATAL -- : app/models/concerns/can_be_authorized.rb:29:in `permissions?'
[3df6460b-4dbc-45d7-8ea4-51783b35e8f4] app/controllers/application_controller/handles_errors.rb:103:in `humanize_error'
[3df6460b-4dbc-45d7-8ea4-51783b35e8f4] app/controllers/application_controller/handles_errors.rb:67:in `block (2 levels) in respond_to_exception'
[3df6460b-4dbc-45d7-8ea4-51783b35e8f4] app/controllers/application_controller/handles_errors.rb:66:in `respond_to_exception'
[3df6460b-4dbc-45d7-8ea4-51783b35e8f4] app/controllers/application_controller/handles_errors.rb:26:in `unprocessable_entity'
I, [2021-09-08T09:34:03.730263 #18716-46957983579280] INFO -- : Completed 500 Internal Server Error in 108690ms (ActiveRecord: 108227.4ms)
F, [2021-09-08T09:34:03.730842 #18716-46957983579280] FATAL -- :
F, [2021-09-08T09:34:03.730862 #18716-46957983579280] FATAL -- : ActiveRecord::StatementInvalid (Mysql2::Error: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2): SELECT 1 AS one FROM `permissions` INNER JOIN `permissions_roles` ON `permissions`.`id` = `permissions_roles`.`permission_id` INNER JOIN `roles` ON `permissions_roles`.`role_id` = `roles`.`id` INNER JOIN `roles_users` ON `roles`.`id` = `roles_users`.`role_id` WHERE `roles_users`.`user_id` = 3 AND `roles`.`active` = TRUE AND `permissions`.`active` = TRUE AND `permissions`.`name` = 'admin' LIMIT 1):
F, [2021-09-08T09:34:03.730872 #18716-46957983579280] FATAL -- :
F, [2021-09-08T09:34:03.731054 #18716-46957983579280] FATAL -- : app/models/concerns/can_be_authorized.rb:29:in `permissions?'
[65f2be2f-d556-4864-a40d-d13b25c6a61d] app/controllers/application_controller/handles_errors.rb:103:in `humanize_error'
[65f2be2f-d556-4864-a40d-d13b25c6a61d] app/controllers/application_controller/handles_errors.rb:67:in `block (2 levels) in respond_to_exception'
[65f2be2f-d556-4864-a40d-d13b25c6a61d] app/controllers/application_controller/handles_errors.rb:66:in `respond_to_exception'
[65f2be2f-d556-4864-a40d-d13b25c6a61d] app/controllers/application_controller/handles_errors.rb:26:in `unprocessable_entity'
MySQL is running fine, I can connect to it using MySQL Workbench both as root user and the zammad user as configured in database.yml
netstat -ln | grep mysql
unix 2 [ ACC ] STREAM LISTENING 446932 /var/run/mysqld/mysqld.sock
My max_allowed_packet is set to 256MB as I’ve read some threads that this could cause similar errors.
I simply cannot figure our why these errors are occurring or how to solve them, please help!
