Multiple PostgreSQL Versions
  • Used Zammad version: 6.0.0-1689342785.e8796845.jammy
  • Used Zammad installation type: Ubuntu package
  • Operating system: Ubuntu 22.10
  • Browser + version: Edge
Question:
  • After upgrading to Ubuntu 20.10 I have two running PostgreSQL server:
12 main 5432 online postgres /var/lib/postgresql/12/main /var/log/postgresql/postgresql-12-main.log
14 main 5434 online postgres /var/lib/postgresql/14/main /var/log/postgresql/postgresql-14-main.log
  • How does Zammad connect to the right version?
  • I understand that Zammad uses unix sockets. So does it just looks for the right database?
  • So I can have as many PostgreSQL versions as I like running as long as there is only one Zamad database?
You need to actually finish your PostgreSQL upgrade and migrate the data from v12 to v14. Your current active version is still the original v12 instance that came with the previous version of your OS. The newer (empty) v14 is running besides that on an alternative port/socket, waiting for you to migrate the data into it.
It is best to migrate to the newer PostgreSQL version and keep in line with the upstream versioning.
You can run multiple major versions of PostgreSQL on the same host. You can even run multiple instances of the same version, with each in their own sandboxed environments. If you do not have a really, really specific use-case for those situations, it is best avoided.
I indeed migrated the database to v14. Which worked fine.
But I still wonder how Zammad knows which PostgreSQL instance it is supposed to connect to. I cannot find any port settigs in the config file.
In Zammad’s default package configuration, it will connect to the local default PostgreSQL socket. You can verify this by various methods, some of which are listed below. Zammad (and other applications) will usually only know of a default socket (or the default TCP/IP port) and will try to connect to that. If you have a pending PostgreSQL package upgrade, there is (still) the default port/socket of your running database, as well as an alternate port/socket for the newly installed database version. After you’ve finished migrating data and finishing the upgrade, the alternate port/socket of the new database will switch to become the new default port/socket.
For example, here is a (shortened) ps auxfww processlisting of the current PostgreSQL processes. I have opened two extra psql client connections, one on the IPv6 localhost address and one on the IPv4 localhost address (username: harrie connecting to database testdb), so you can see the difference between socket and TCP/IP client connection slots.
USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
postgres     716  0.0  0.3 219668 27784 ?        Ss   Jun16   1:10 /usr/lib/postgresql/15/bin/postgres -D /var/lib/postgresql/15/main -c config_file=/etc/postgresql/15/main/postgresql.conf
postgres     728  0.0  0.2 219796 19576 ?        Ss   Jun16   0:10  \_ postgres: 15/main: checkpointer
postgres     729  0.0  0.1 219812 11316 ?        Ss   Jun16   0:15  \_ postgres: 15/main: background writer
postgres     748  0.0  0.1 219668  9432 ?        Ss   Jun16   2:27  \_ postgres: 15/main: walwriter
postgres     749  0.0  0.0 221256  8016 ?        Ss   Jun16   0:15  \_ postgres: 15/main: autovacuum launcher
postgres     750  0.0  0.0 221240  6304 ?        Ss   Jun16   0:00  \_ postgres: 15/main: logical replication launcher
postgres  763245  0.0  0.2 223188 18832 ?        Ss   Jul17   0:09  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763246  0.0  0.2 222560 19384 ?        Ss   Jul17   0:02  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763249  0.0  0.2 222560 18552 ?        Ss   Jul17   0:00  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763260  0.0  0.2 222560 18532 ?        Ss   Jul17   0:00  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763262  0.0  0.2 222560 22208 ?        Ss   Jul17   0:04  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763265  0.0  0.3 222728 24488 ?        Ss   Jul17   0:00  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763267  0.0  0.2 222560 22700 ?        Ss   Jul17   0:00  \_ postgres: 15/main: zammad zammad [local] idle
postgres  763269  0.0  0.3 224844 29268 ?        Ss   Jul17   0:05  \_ postgres: 15/main: zammad zammad [local] idle
postgres  781960  0.0  0.2 222560 18640 ?        Ss   Jul18   0:00  \_ postgres: 15/main: zammad zammad [local] idle
postgres  804515  0.0  0.2 222248 16340 ?        Ss   11:12   0:00  \_ postgres: 15/main: harrie testdb 127.0.0.1(35664) idle
postgres  804532  0.0  0.1 221764 15632 ?        Ss   11:13   0:00  \_ postgres: 15/main: harrie testdb ::1(54038) idle
You can use lsof to check for connected sockets, or established TCP/IP connections. This is a list of connected sockets where the users are either postgres or zammad:
root@zammad:~# lsof -a -U -upostgres -uzammad|grep CONNECTED
ruby     762905   zammad    1u  unix 0x00000000a3403c8b      0t0 3409990 type=STREAM (CONNECTED)
ruby     762905   zammad    2u  unix 0x00000000a3403c8b      0t0 3409990 type=STREAM (CONNECTED)
ruby     762907   zammad    1u  unix 0x00000000f0bc9ea9      0t0 3409986 type=STREAM (CONNECTED)
ruby     762907   zammad    2u  unix 0x00000000f0bc9ea9      0t0 3409986 type=STREAM (CONNECTED)
ruby     762909   zammad    1u  unix 0x00000000b6750a5f      0t0 3409994 type=STREAM (CONNECTED)
ruby     762909   zammad    2u  unix 0x00000000b6750a5f      0t0 3409994 type=STREAM (CONNECTED)
ruby     762909   zammad    6u  unix 0x0000000048a1b756      0t0 3410398 type=STREAM (CONNECTED)
ruby     762909   zammad    8u  unix 0x00000000dd30b4d8      0t0 3411161 type=STREAM (CONNECTED)
ruby     762909   zammad    9u  unix 0x00000000f533f31c      0t0 3411166 type=STREAM (CONNECTED)
ruby     762909   zammad   10u  unix 0x00000000736b67d2      0t0 3410409 type=STREAM (CONNECTED)
ruby     762909   zammad   11u  unix 0x0000000008c9d59a      0t0 3410411 type=STREAM (CONNECTED)
ruby     762909   zammad   12u  unix 0x0000000096fa9576      0t0 3411182 type=STREAM (CONNECTED)
ruby     762909   zammad   13u  unix 0x000000006c24eedb      0t0 3410422 type=STREAM (CONNECTED)
ruby     762909   zammad   14u  unix 0x0000000018575749      0t0 3410424 type=STREAM (CONNECTED)
ruby     762909   zammad   15u  unix 0x00000000d87a258c      0t0 3541462 type=STREAM (CONNECTED)
postgres 763245 postgres    8u  unix 0x0000000051f66b89      0t0 3410399 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763246 postgres    8u  unix 0x00000000587fc077      0t0 3410402 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763249 postgres    8u  unix 0x00000000f71a217d      0t0 3410405 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763260 postgres    8u  unix 0x0000000058fb321a      0t0 3410410 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763262 postgres    8u  unix 0x00000000f1f70b81      0t0 3410412 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763265 postgres    8u  unix 0x000000007eb20fe1      0t0 3410421 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763267 postgres    8u  unix 0x000000007fbc8515      0t0 3410423 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 763269 postgres    8u  unix 0x00000000940dbe42      0t0 3410425 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
postgres 781960 postgres    8u  unix 0x00000000316f9ac2      0t0 3541463 /var/run/postgresql/.s.PGSQL.5432 type=STREAM (CONNECTED)
This is a list of established TCP/IP connections where the users are either postgres or zammad. You can see my IPv4 and IPv6 database connections in the list. The connections to redis are obviously not relevant here:
root@zammad:~# lsof -a -i -upostgres -uzammad|grep ESTABLISHED
ruby     762905   zammad    7u  IPv4 3411160      0t0  TCP localhost:41412->localhost:redis (ESTABLISHED)
ruby     762907   zammad    7u  IPv4 3410393      0t0  TCP localhost:41398->localhost:redis (ESTABLISHED)
ruby     762909   zammad    7u  IPv4 3411157      0t0  TCP localhost:41390->localhost:redis (ESTABLISHED)
psql     804513 postgres    3u  IPv4 3642604      0t0  TCP localhost:35664->localhost:postgresql (ESTABLISHED)
postgres 804515 postgres    8u  IPv4 3642605      0t0  TCP localhost:postgresql->localhost:35664 (ESTABLISHED)
postgres 804532 postgres    8u  IPv6 3642627      0t0  TCP localhost:postgresql->localhost:54038 (ESTABLISHED)
You can also check which connection slots are in use by query’ing it from the database. Here you can also see the difference between clients which are connected via a socket, as well as clients which have connected via TCP/IP (check the client_addr and client_port columns):
postgres=# SELECT * FROM pg_stat_activity ;
 datid | datname  |  pid   | leader_pid | usesysid | usename  |      application_name       | client_addr | client_hostname | client_port |         backend_start         |          xact_start          |          query_start          |         state_change          | wait_event_type |     wait_event      | state  | backend_xid | backend_xmin | query_id |        query        |         backend_type
       |          |    750 |            |       10 | postgres |                             |             |                 |             | 2023-06-16 01:29:52.431354+02 |                              |                               |                               | Activity        | LogicalLauncherMain |        |             |              |          |        | logical replication launcher
       |          |    749 |            |          |          |                             |             |                 |             | 2023-06-16 01:29:52.433256+02 |                              |                               |                               | Activity        | AutoVacuumMain      |        |             |              |          |        | autovacuum launcher
 16389 | zammad   | 763245 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:35.115622+02 |                              | 2023-07-19 11:34:06.185107+02 | 2023-07-19 11:34:06.185151+02 | Client          | ClientRead          | idle   |             |              |          | UPDATE "delayed_jobs" SET locked_at = '2023-07-19 09:34:06.184570', locked_by = 'host:zammad pid:762909' WHERE id IN (SELECT "delayed_jobs"."id" FROM "delayed_jobs" WHERE (((run_at <= '2023-07-19 09:34:06.184251' AND (locked_at IS NULL OR locked_at < '2023-07-12 09:34:06.184262')) OR locked_by = 'host:zammad pid:762909') AND failed_at IS NULL) ORDER BY priority ASC, run_at ASC LIMIT 1 FOR UPDATE) RETURNING * | client backend
 16389 | zammad   | 763246 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:35.119651+02 |                              | 2023-07-19 11:34:01.391621+02 | 2023-07-19 11:34:01.391682+02 | Client          | ClientRead          | idle   |             |              |          | SELECT "schedulers".* FROM "schedulers" WHERE "schedulers"."active" = $1 ORDER BY "schedulers"."prio" ASC        | client backend
 16389 | zammad   | 763249 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:35.15163+02  |                              | 2023-07-17 21:15:35.175234+02 | 2023-07-17 21:15:35.179372+02 | Client          | ClientRead          | idle   |             |              |          | COMMIT        | client backend
 16389 | zammad   | 763260 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:36.135799+02 |                              | 2023-07-17 21:15:36.156834+02 | 2023-07-17 21:15:36.156858+02 | Client          | ClientRead          | idle   |             |              |          | SELECT "channels".* FROM "channels" WHERE (active = TRUE AND area LIKE '%::Account')        | client backend
 16389 | zammad   | 763262 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:37.136198+02 |                              | 2023-07-19 11:33:46.774424+02 | 2023-07-19 11:33:46.774442+02 | Client          | ClientRead          | idle   |             |              |          | SELECT "schedulers".* FROM "schedulers" WHERE "schedulers"."id" = $1 LIMIT $2        | client backend
 16389 | zammad   | 763265 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:38.136523+02 |                              | 2023-07-19 11:30:52.751694+02 | 2023-07-19 11:30:52.751712+02 | Client          | ClientRead          | idle   |             |              |          | SELECT "schedulers".* FROM "schedulers" WHERE "schedulers"."id" = $1 LIMIT $2        | client backend
 16389 | zammad   | 763267 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:39.144142+02 |                              | 2023-07-19 11:30:52.747265+02 | 2023-07-19 11:30:52.747285+02 | Client          | ClientRead          | idle   |             |              |          | SELECT "schedulers".* FROM "schedulers" WHERE "schedulers"."id" = $1 LIMIT $2        | client backend
 16389 | zammad   | 763269 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-17 21:15:40.14449+02  |                              | 2023-07-19 11:29:10.339064+02 | 2023-07-19 11:29:10.341471+02 | Client          | ClientRead          | idle   |             |              |          | COMMIT        | client backend
 16389 | zammad   | 781960 |            |    16388 | zammad   | script/background-worker.rb |             |                 |          -1 | 2023-07-18 12:32:49.84389+02  |                              | 2023-07-18 12:32:49.857598+02 | 2023-07-18 12:32:49.861408+02 | Client          | ClientRead          | idle   |             |              |          | COMMIT        | client backend
 18652 | testdb   | 804515 |            |    18650 | harrie   | psql                        | 127.0.0.1   |                 |       35664 | 2023-07-19 11:12:43.658244+02 |                              |                               | 2023-07-19 11:12:43.670095+02 | Client          | ClientRead          | idle   |             |              |          |        | client backend
 18652 | testdb   | 804532 |            |    18650 | harrie   | psql                        | ::1         |                 |       54038 | 2023-07-19 11:13:03.724122+02 |                              |                               | 2023-07-19 11:13:03.734204+02 | Client          | ClientRead          | idle   |             |              |          |        | client backend
     5 | postgres | 804944 |            |       10 | postgres | psql                        |             |                 |          -1 | 2023-07-19 11:32:51.315059+02 | 2023-07-19 11:34:07.31679+02 | 2023-07-19 11:34:07.31679+02  | 2023-07-19 11:34:07.316791+02 |                 |                     | active |             |       313195 |          | SELECT * FROM pg_stat_activity ;        | client backend
       |          |    729 |            |          |          |                             |             |                 |             | 2023-06-16 01:29:52.365232+02 |                              |                               |                               | Activity        | BgWriterHibernate   |        |             |              |          |        | background writer
       |          |    728 |            |          |          |                             |             |                 |             | 2023-06-16 01:29:52.365541+02 |                              |                               |                               | Activity        | CheckpointerMain    |        |             |              |          |        | checkpointer
       |          |    748 |            |          |          |                             |             |                 |             | 2023-06-16 01:29:52.431954+02 |                              |                               |                               | Activity        | WalWriterMain       |        |             |              |          |        | walwriter
(17 rows)
Thanks a lot dvanzuijlekom!
Now I understand a lot more.
