Title: Multi-Select toggle for External Data Source Field Objects
Currently, External Data Source Field Objects are only single-select. In order to replicate multi-select functionality within Zammad, multiple objects of this type are required, along with the workflows to show these when required. -
When feeding Zammad with large amounts of data, populating the traditional select/tree-select objects with tens of thousands of items results in slow page loading times. -
Existing object does not have a multi-select variant or toggle. -
By adding a toggle to External Data Source Field Objects, admins could choose their default behavior.
The additional advantage of a toggle rather than an additional object type could be that the toggle could be switched with a core workflow, so the same object could be used for both single-select and multi-select.
Your Zammad environment:
- Average concurrent agent count: 60
- Average tickets a day: 400
- What roles/people are involved: IT Support and Site teams supporting 19 schools
N/A
