MS 365 Kiosk License
i am new with zammad and i like it very much. i want to add a mailbox for receiving and sending mails, is it possible to use a mailbox at office 365 with an kiosk license? The Kiosk license has a limited mailbox store of 2gb and should onyl have access via pop and smtp. not sure if modern authentication is used here.
best regards
Andreas
You need IMAP and SMTP at all times, even with modern authentication (which is only about the authentication).
I can’t answer your question regarding Microsoft 365 licensing.
