Moving objects between title and text
Hi, is there any way to move the Object: “Ticketinfo” between the Title and the Text field?
I have tried to adjust the position with the intended object numbering but the ticket info field does not go up any further
  • Used Zammad version: 6.1.0-1696849338.59fe2e15.bookworm
  • Operating system: Windows 10 22H2
  • Browser + version: Chrome 119.0.6045.160
Thanks a lot
Is this a better solution for you?
https://docs.zammad.org/en/latest/admin/console/hidden-settings.html#adding-a-warning-to-the-ticket-creation-process
I don‘t know how you can switch the position. Maybe in Admin area > objects > tickets the priority?!
Currently, it’s not possible to move an object attribute between the title and text.
alright, thanks a lot for the fast reply. :slight_smile:
