Monitoring stuck import backend import:ldap
Used zammad version: 6.0
Installation type: package
Operating system: Ubuntu 22.04 LTS
Zammad seems to be stuck doing something and it’s getting 401 unauthorized, CSRF token failed
And the monitoring status seems to be stuck with "Stuck import backend ‘Import::Ldap’ with scheduler may not run message
So is the worker service running or not…?
Restarting Zammad might “solve” the issue.
If you have no issues on your agents and general user base, you can safely ignore it.
