- Used Zammad version: 6.3.1
- Used Zammad installation type: docker in portainer
- Operating system: Ubuntu Server 22.04
- Browser + version: Chrome 128.0.6613.85
I want to use the mobile version but not working properly due to /cable connection.
I installed in portainer using docker. Everything seems working in desktop. The Zammad server is ehind Nginx Proxy Manager with this configuration:
location /ws {
proxy_http_version 1.1;
proxy_read_timeout 86400;
proxy_pass http://127.0.0.1:6042;
# action cable
location /cable {
proxy_pass http://127.0.0.1:3000;
These are the error that im getting.
I check some post on the forum and any worked for me. I see a post using this config too:
location / {
# Change this line in an SSO setup
proxy_read_timeout 300;
proxy_pass http://192.168.62.44:3000;
gzip on;
gzip_proxied any;
The problem if I put this on the config is that the webserver gives 502 error (modifying the ip to mine).
I hope this is a silly mistake but I can’t see it. Thanks
