Used Zammad version: 6.3.1-1721805003.877871eb.bookworm
Operating system: Debian 12
Browser + version: Chrome 128.0.6613.138
An outgoing mail should retain the Gitlab specific headers.
This would enable automatic assignment in Gitlab.
An incoming email from Gitlab is assigned to a ticket and as soon as you reply by email from Zammad, all Gitlab-specific X-headers (e.g. X-GitLab-Issue-ID: 12345) are no longer existent in the sent email.
Unfortunately, this means that Gitlab is unable to assign the email to a specific issue and replies with an error.
There is no way to keep them where they are.
I just checked with a Github mail in my Thunderbird: My thunderbird also removes the X-Headers. I personally think that this is expected, because these headers are relevant for the current routing of the mail (so when you received it), not for sending it.
Many thanks you for the info.
In fact, I only just noticed that Gitlab also uses references and reply-to to assign replies.
But for some reason there seem to be problems here when I send an email from Zammad, as these cannot be assigned by Gitlab.
If I reply directly from the email account associated with Zammad, it works without any problems.
Are there any other things in the mail setup in Zammad that I could check?
