Migration Error
Hi Everyone,
I am running a migration from OTRS 5 (ubuntu 16.04) to Zammad 3.3.x (Ubuntu 18.04)
  • Used Zammad version: 3.3.x
  • Used Zammad installation source:
  • Browser + version: Chrome 81.0.4044.113
Migration completes successfully.
PG::ForeignKeyViolation: ERROR: insert or update on table “tickets” violates foreign key constraint “fkrailsf39559d6d6” DETAIL: Key (group_id)=(0) is not present in table “groups”. : INSERT INTO “tickets” (“id”, “groupid”, “priorityid”, “stateid”, “number”, “title”, “ownerid”, “customerid”, “updatedbyid”, “createdbyid”, “createdat”, “updated_at”) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12) RETURNING “id”
I have only attempted this once, but I installed both extensions into OTRS and then ran the migration from Zammad web UI.
here is a screenshot of error
Just to be sure, did you run the migration twice?
If so, please ensure to start from scratch, because otherwise this won’t work.
this was the first time i ran the migration, i have since migrated successfully onto seperate ubunutu install using command line.
just a question, when the migration fails how do i cancel it so that i can re-run it, i tried droppping the daabase but that didnt seem to work.
Thanks
You need to stop all Zammad service.
Dropping the database is protected. Sorry, but I won’t get in detail on how to overcome this protection because the error message does tell you what environment variable needs to be set.
This is to protect users from doing potential dangerous operations.
