Mentioned Person
  • Used Zammad version:
  • Operating system: Windows
  • Browser + version:Google Chrome Version 114.0.5735.134 (Official Build) (64-Bit)
###Expected Behavior:
*I would like to see the tickets where the other people are mentioned, but i can’t find the correct orders.
Hi @tokasokamo, please make sure to use the template in the correct way, fill out all required information, and try to describe your issue as detailed as possible. Without this, it’s quite hard to help you…
@fliebe92 thank you. Do you know where i can find the list of all commands?
Sorry, what commands are you referring to?
