Used Zammad version: 2.6.x
Installation method (source, package, …): package
Operating system: Debian 9.5
Database + version: mysqld 10.1.26-MariaDB-0+deb9u1
Elasticsearch version: 5.6.10
Browser + version: Independent from browser
Search output is displayed (Searchs Tickets, Companies etc.)
Every search in Zammad that uses Elasticsearch displays: StatusCode: 500
Search
Yes I’m sure this is a bug and no feature request or a general question.
System was rebooted, all services restarted.
The max_allowed_packet-warning is added to every elasticsearch query, so the elasticsearch URL is broken. The max_allowed_packet is actually 128M, the maximum mailsize in Zammad 64MB. Fetching mails works fine.
This is production.log output, where you can see that the URL sent to Elasticsearch contains the error that max_allowed_packet is too low - which is not the case.
http://127.0.0.1:9200/zammad_production/User/_search"
E, [2018-08-14T06:51:00.572197 #959] ERROR – : bad URI(is not URI?): Warning: Database config value ‘max_allowed_packet’ less than Zammad setting ‘Maximum Email Size’
Zammad will fail to process emails (both incoming and outgoing)
larger than the value of ‘max_allowed_packet’ (64MB).
Please increase this value in your MariaDB configuration accordingly.
Health says:
181 failing background jobs.
Failed to run background job #1 ‘BackgroundJobSearchIndex’ 10 time(s) with 180 attempt(s).
Github Issue which leads here:
