From the log file you provided the database seems to be at least instable just as your database server:
E, [2021-09-22T10:03:33.039521 #47290-47235079120100] ERROR -- : PG::UnableToSend: server closed the connection unexpectedly
E, [2021-09-22T10:03:33.039877 #47284-47235080223460] ERROR -- : PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly
E, [2021-09-22T10:03:33.045215 #47288-47235079308700] ERROR -- : PG::UnableToSend: server closed the connection unexpectedly
E, [2021-09-22T10:03:33.046500 #47284-47235080223760] ERROR -- : PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly
E, [2021-09-22T10:03:33.053611 #47130-46940618758560] ERROR -- : #<PG::ConnectionBad: server closed the connection unexpectedly
E, [2021-09-22T10:03:33.053733 #47130-46940618758560] ERROR -- : ["/opt/zammad/vendor/bundle/ruby/2.6.0/gems/pg-0.21.0/lib/pg.rb:56:in `initialize'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/pg-0.21.0/lib/pg.rb:56:in `new'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/pg-0.21.0/lib/pg.rb:56:in `connect'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/postgresql_adapter.rb:692:in `connect'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/postgresql_adapter.rb:223:in `initialize'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/postgresql_adapter.rb:48:in `new'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/postgresql_adapter.rb:48:in `postgresql_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:830:in `new_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:874:in `checkout_new_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:853:in `try_to_checkout_new_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:814:in `acquire_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:538:in `checkout'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:382:in `connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/abstract/connection_pool.rb:1033:in `retrieve_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_handling.rb:118:in `retrieve_connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_handling.rb:90:in `connection'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/core.rb:280:in `cached_find_by_statement'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/core.rb:201:in `find_by'", "/opt/zammad/lib/sessions/event/base.rb:95:in `current_user'", "/opt/zammad/lib/sessions/event/base.rb:118:in `permission_check'", "/opt/zammad/lib/sessions/event/chat_agent_state.rb:24:in `run'", "/opt/zammad/lib/sessions/event.rb:15:in `run'", "/opt/zammad/lib/websocket_server.rb:100:in `onmessage'", "/opt/zammad/lib/websocket_server.rb:25:in `block (3 levels) in run'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/em-websocket-0.5.1/lib/em-websocket/connection.rb:18:in `trigger_on_message'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/em-websocket-0.5.1/lib/em-websocket/message_processor_06.rb:52:in `message'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/em-websocket-0.5.1/lib/em-websocket/framing07.rb:118:in `process_data'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/em-websocket-0.5.1/lib/em-websocket/handler.rb:47:in `receive_data'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/em-websocket-0.5.1/lib/em-websocket/connection.rb:76:in `receive_data'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:in `run_machine'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/eventmachine-1.2.7/lib/eventmachine.rb:195:in `run'", "/opt/zammad/lib/websocket_server.rb:10:in `run'", "script/websocket-server.rb:129:in `<top (required)>'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'", "/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'", "/opt/zammad/bin/bundle:3:in `load'", "/opt/zammad/bin/bundle:3:in `<main>'"]
E, [2021-09-22T10:03:33.068733 #47284-47235079308700] ERROR -- : PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly
E, [2021-09-22T10:03:34.073187 #47284-70164434248400] ERROR -- : FATAL: el sistema de base de datos está en modo de recuperación
E, [2021-09-22T10:03:34.078137 #47284-70164434248400] ERROR -- : Error ID _ia7J4V4: FATAL: el sistema de base de datos está en modo de recuperación
E, [2021-09-22T10:03:34.151167 #47286-47235079308700] ERROR -- : invalid encoding name: utf8 (PG::Error)
E, [2021-09-22T10:03:34.151836 #47286-47235079308700] ERROR -- : Error ID 9lS41bGV: invalid encoding name: utf8
E, [2021-09-22T10:03:34.172941 #47132-46972981536960] ERROR -- : thread_client 46940698473100 exited with error #<ActiveRecord::StatementInvalid: PG::ConnectionBad: PQconsumeInput() server closed the connection unexpectedly
E, [2021-09-22T10:03:34.173073 #47132-46972981536960] ERROR -- : /opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.6/lib/active_record/connection_adapters/postgresql_adapter.rb:611:in `async_exec'
You may want to find the root of that issue.
It seems your connecting to a non local database server - for this to be no issue, please ensure the database connection is stable and suitable for that approach.
