I’ve tracked down one of the events, though I’ll be honest in that I don’t understand it enough to see if anything is wrong here. It looks like the same thing is just running twice.
The two events for customer creation are about 1.5 seconds apart.
Our network is just over a switch to the server. Does this look like some kind of a bounce?
Thanks.
Log block
I, [2019-08-26T16:27:34.458257 #8596-69848214619480] INFO -- : Started PUT "/api/v1/taskbar/1084" for 192.168.0.119 at 2019-08-26 16:27:34 +0000
I, [2019-08-26T16:27:34.469663 #8596-69848214619480] INFO -- : Processing by TaskbarController#update as JSON
I, [2019-08-26T16:27:34.469855 #8596-69848214619480] INFO -- : Parameters: {"key"=>"Ticket-345", "client_id"=>"123", "callback"=>"TicketZoom", "state"=>{"ticket"=>{}, "article"=>{"form_id"=>"836754793"}}, "params"=>{"ticket_id"=>"345", "shown"=>true}, "prio"=>8, "notify"=>false, "active"=>true, "attachments"=>[], "updated_at"=>"2019-08-26T16:25:32.332Z", "id"=>"1084"}
I, [2019-08-26T16:27:34.547288 #8596-69848214619480] INFO -- : Completed 200 OK in 77ms (Views: 1.2ms | ActiveRecord: 19.1ms)
I, [2019-08-26T16:27:46.586224 #8596-69848115709440] INFO -- : Started POST "/api/v1/users" for 192.168.0.131 at 2019-08-26 16:27:46 +0000
I, [2019-08-26T16:27:46.598232 #8596-69848115709440] INFO -- : Processing by UsersController#create as JSON
I, [2019-08-26T16:27:46.598424 #8596-69848115709440] INFO -- : Parameters: {"firstname"=>"XXXXXX", "lastname"=>"XXXXXX", "email"=>"", "web"=>"", "password"=>"[FILTERED]", "phone"=>"xxx-xxx-xxxx", "fax"=>"", "mobile"=>"", "organization_id"=>"8", "department"=>"", "note"=>"", "role_ids"=>[], "group_ids"=>{"1"=>[], "2"=>[]}, "active"=>true, "address"=>"", "location"=>"", "vip"=>false, "id"=>"c-749"}
I, [2019-08-26T16:27:46.680520 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 1ec92836-35b0-4fb9-afd5-4f49f3420960) to DelayedJob(default) with arguments: "User", 434
I, [2019-08-26T16:27:46.698617 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 7dde9051-2f4d-4b05-8e5c-366cbdfc8ae8) to DelayedJob(default) with arguments: "Organization", 8
I, [2019-08-26T16:27:46.711966 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 5173c81f-42a4-454e-a72e-75c1e3c45bc3) to DelayedJob(default) with arguments: "User", 286
I, [2019-08-26T16:27:46.722859 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 7411e3bb-1795-4e86-a057-025d3175d626) to DelayedJob(default) with arguments: "User", 5
I, [2019-08-26T16:27:46.733697 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 04c78f3d-e3df-4bc0-9de5-d09e7f3db8b8) to DelayedJob(default) with arguments: "User", 155
I, [2019-08-26T16:27:46.744619 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 8bd84a8a-a9b8-42d2-a2d3-22ee24ec5ea6) to DelayedJob(default) with arguments: "User", 66
I, [2019-08-26T16:27:46.755437 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: f8e9668d-410f-46c3-8acd-f2099c175aea) to DelayedJob(default) with arguments: "User", 89
I, [2019-08-26T16:27:46.766244 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 94ce7508-e997-49e8-b76c-b6156d49445c) to DelayedJob(default) with arguments: "User", 198
I, [2019-08-26T16:27:46.776458 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 8c3e0a91-a57e-4f05-9fa7-107bec9d5b4f) to DelayedJob(default) with arguments: "User", 52
I, [2019-08-26T16:27:46.786963 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: e8bcc3d1-8817-4b32-91ec-fb7d2860bc64) to DelayedJob(default) with arguments: "User", 246
I, [2019-08-26T16:27:46.797193 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 32fe9223-e755-458d-ad2d-381017c374ce) to DelayedJob(default) with arguments: "User", 152
I, [2019-08-26T16:27:46.807670 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 27303e53-680f-437e-acc2-b7bc34ef6580) to DelayedJob(default) with arguments: "User", 32
I, [2019-08-26T16:27:46.818094 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: a49e117b-f611-4cab-9354-9eb8785ca10a) to DelayedJob(default) with arguments: "User", 64
I, [2019-08-26T16:27:46.828429 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 4e10305a-33dc-4ae2-addc-bd6da4bd7dc0) to DelayedJob(default) with arguments: "User", 393
I, [2019-08-26T16:27:46.838843 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 129bf717-f100-4814-a3f9-7942e220c132) to DelayedJob(default) with arguments: "User", 362
I, [2019-08-26T16:27:46.849707 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: 6de90968-8158-4833-bcce-0583726403a5) to DelayedJob(default) with arguments: "User", 310
I, [2019-08-26T16:27:46.859947 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: bfed7e10-f93e-449a-8283-9817066089cd) to DelayedJob(default) with arguments: "User", 189
I, [2019-08-26T16:27:46.870415 #8596-69848115709440] INFO -- : Enqueued SearchIndexJob (Job ID: ae8f1552-fac4-4dcf-b60e-edc1a5a30ded) to DelayedJob(default) with arguments: "User", 291
I, [2019-08-26T16:27:46.907610 #8596-69848115709440] INFO -- : Performing UpdateCtiLogsByCallerJob (Job ID: 3a73748f-ca40-4e45-90a7-14762264885f) from DelayedJob(default) with arguments: "1566836866981630", {:limit=>20}
I, [2019-08-26T16:27:47.075286 #8596-69848115709440] INFO -- : Performed UpdateCtiLogsByCallerJob (Job ID: 3a73748f-ca40-4e45-90a7-14762264885f) from DelayedJob(default) in 167.44ms
I, [2019-08-26T16:27:47.098839 #8596-69848115709440] INFO -- : Enqueued UpdateCtiLogsByCallerJob (Job ID: 4555fe9b-b15a-4ab8-b515-63e899f14852) to DelayedJob(default) with arguments: "1566836866981630", {:limit=>40, :offset=>20}
I, [2019-08-26T16:27:47.113788 #8596-69848115709440] INFO -- : Performing UpdateCtiLogsByCallerJob (Job ID: f50a28e3-e9e0-4525-aae9-c2b50b6ab3eb) from DelayedJob(default) with arguments: "5098212699", {:limit=>20}
I, [2019-08-26T16:27:47.117667 #8596-69848115709440] INFO -- : Performed UpdateCtiLogsByCallerJob (Job ID: f50a28e3-e9e0-4525-aae9-c2b50b6ab3eb) from DelayedJob(default) in 3.75ms
I, [2019-08-26T16:27:47.140454 #8596-69848115709440] INFO -- : Enqueued UpdateCtiLogsByCallerJob (Job ID: 367a696d-a45a-4cc0-b552-ec622a95b39c) to DelayedJob(default) with arguments: "5098212699", {:limit=>40, :offset=>20}
I, [2019-08-26T16:27:47.204332 #8596-69848115709440] INFO -- : Completed 201 Created in 606ms (Views: 0.8ms | ActiveRecord: 170.5ms)
I, [2019-08-26T16:27:47.224802 #8596-69848220920760] INFO -- : Started GET "/api/v1/users/434?full=true&_=1566824998114" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.231100 #8596-69848220920760] INFO -- : Processing by UsersController#show as JSON
I, [2019-08-26T16:27:47.231219 #8596-69848220920760] INFO -- : Parameters: {"full"=>"true", "_"=>"1566824998114", "id"=>"434"}
I, [2019-08-26T16:27:47.742610 #8596-69848220920760] INFO -- : Completed 200 OK in 511ms (Views: 13.3ms | ActiveRecord: 90.6ms)
I, [2019-08-26T16:27:47.822602 #8596-69848122310480] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=198&_=1566824998115" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.828263 #8596-69848220895880] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=198&_=1566824998116" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.835935 #8596-69848122310480] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:47.836110 #8596-69848122310480] INFO -- : Parameters: {"customer_id"=>"198", "_"=>"1566824998115"}
I, [2019-08-26T16:27:47.839151 #8596-69848115709440] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=393&_=1566824998117" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.846744 #8596-69848220895880] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:47.846920 #8596-69848220895880] INFO -- : Parameters: {"customer_id"=>"198", "_"=>"1566824998116"}
I, [2019-08-26T16:27:47.848270 #8596-69848214619480] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=393&_=1566824998118" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.865638 #8596-69848115709440] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:47.875111 #8596-69848115709440] INFO -- : Parameters: {"customer_id"=>"393", "_"=>"1566824998117"}
I, [2019-08-26T16:27:47.866649 #8596-69848220920760] INFO -- : Started GET "/api/v1/templates/?full=true&_=1566824998119" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.877289 #8596-69848115692280] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=434&_=1566824998120" for 192.168.0.131 at 2019-08-26 16:27:47 +0000
I, [2019-08-26T16:27:47.904358 #8596-69848220920760] INFO -- : Processing by TemplatesController#index as JSON
I, [2019-08-26T16:27:47.904534 #8596-69848220920760] INFO -- : Parameters: {"full"=>"true", "_"=>"1566824998119"}
I, [2019-08-26T16:27:47.870140 #8596-69848214619480] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:47.910960 #8596-69848214619480] INFO -- : Parameters: {"customer_id"=>"393", "_"=>"1566824998118"}
I, [2019-08-26T16:27:47.958258 #8596-69848115692280] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:47.958445 #8596-69848115692280] INFO -- : Parameters: {"customer_id"=>"434", "_"=>"1566824998120"}
I, [2019-08-26T16:27:48.018682 #8596-69848220920760] INFO -- : Completed 200 OK in 114ms (Views: 0.4ms | ActiveRecord: 57.6ms)
I, [2019-08-26T16:27:48.044650 #8596-69848115692280] INFO -- : Completed 200 OK in 80ms (Views: 0.5ms | ActiveRecord: 34.5ms)
I, [2019-08-26T16:27:48.048165 #8596-69848220920760] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=434&_=1566824998121" for 192.168.0.131 at 2019-08-26 16:27:48 +0000
I, [2019-08-26T16:27:48.065775 #8596-69848220920760] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:48.065947 #8596-69848220920760] INFO -- : Parameters: {"customer_id"=>"434", "_"=>"1566824998121"}
I, [2019-08-26T16:27:48.105645 #8596-69848115692280] INFO -- : Started POST "/api/v1/users" for 192.168.0.131 at 2019-08-26 16:27:48 +0000
I, [2019-08-26T16:27:48.122554 #8596-69848115692280] INFO -- : Processing by UsersController#create as JSON
I, [2019-08-26T16:27:48.122819 #8596-69848115692280] INFO -- : Parameters: {"firstname"=>"XXXXXX", "lastname"=>"XXXXXX", "email"=>"", "web"=>"", "password"=>"[FILTERED]", "phone"=>"xxx-xxx-xxxx", "fax"=>"", "mobile"=>"", "organization_id"=>"8", "department"=>"", "note"=>"", "role_ids"=>[], "group_ids"=>{"1"=>[], "2"=>[]}, "active"=>true, "address"=>"", "location"=>"", "vip"=>false, "id"=>"c-768"}
I, [2019-08-26T16:27:48.129089 #8596-69848220920760] INFO -- : Completed 200 OK in 63ms (Views: 0.3ms | ActiveRecord: 31.6ms)
I, [2019-08-26T16:27:48.390068 #8596-69848115709440] INFO -- : Completed 200 OK in 512ms (Views: 46.8ms | ActiveRecord: 81.8ms)
I, [2019-08-26T16:27:48.422565 #8596-69848220895880] INFO -- : Completed 200 OK in 575ms (Views: 23.7ms | ActiveRecord: 93.6ms)
I, [2019-08-26T16:27:48.429348 #8596-69848214619480] INFO -- : Completed 200 OK in 510ms (Views: 20.7ms | ActiveRecord: 79.7ms)
I, [2019-08-26T16:27:48.432017 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: b251531a-770a-45bc-9443-70ff9f11f647) to DelayedJob(default) with arguments: "User", 435
I, [2019-08-26T16:27:48.460421 #8596-69848122310480] INFO -- : Completed 200 OK in 624ms (Views: 19.0ms | ActiveRecord: 84.6ms)
I, [2019-08-26T16:27:48.479492 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: a7372c92-a008-464c-b556-753ebd1272a5) to DelayedJob(default) with arguments: "Organization", 8
I, [2019-08-26T16:27:48.491318 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 4fe25e74-e941-495e-ac82-fa4a9b9a4a03) to DelayedJob(default) with arguments: "User", 286
I, [2019-08-26T16:27:48.500874 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 06a45198-3afa-4275-a267-1d722e1b0402) to DelayedJob(default) with arguments: "User", 5
I, [2019-08-26T16:27:48.510375 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 9c4e0810-cf7c-4eb7-9369-f85485ff9bc1) to DelayedJob(default) with arguments: "User", 155
I, [2019-08-26T16:27:48.519821 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: c2b8309c-a7b3-4ded-a57f-d8f5c4cc5979) to DelayedJob(default) with arguments: "User", 66
I, [2019-08-26T16:27:48.529176 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: cca284cd-dbea-47dc-abe1-854cdd02dff5) to DelayedJob(default) with arguments: "User", 89
I, [2019-08-26T16:27:48.538823 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 9df1b6c6-6e4e-451c-a4ee-cd6f2b879e05) to DelayedJob(default) with arguments: "User", 198
I, [2019-08-26T16:27:48.548299 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 9b5940ef-218b-4a0f-9dcc-d4d89c29ca10) to DelayedJob(default) with arguments: "User", 52
I, [2019-08-26T16:27:48.557780 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: dbad5b77-88db-4027-9288-cb0ff6935729) to DelayedJob(default) with arguments: "User", 246
I, [2019-08-26T16:27:48.567286 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 51627b8f-0293-4703-a0c7-8f9ea44fde97) to DelayedJob(default) with arguments: "User", 152
I, [2019-08-26T16:27:48.576888 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 6085b23d-71b6-4037-8d60-931932fb0434) to DelayedJob(default) with arguments: "User", 32
I, [2019-08-26T16:27:48.586375 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 3845260a-eeb3-45ab-baf3-30735430bfab) to DelayedJob(default) with arguments: "User", 64
I, [2019-08-26T16:27:48.595790 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 7511193f-9a8a-45ef-be9c-d6eaf8630443) to DelayedJob(default) with arguments: "User", 393
I, [2019-08-26T16:27:48.605124 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 21ce8f27-0366-4420-965f-5bd7482c3ea8) to DelayedJob(default) with arguments: "User", 362
I, [2019-08-26T16:27:48.614625 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: 3d78bb02-f5cd-4387-893f-4ea52d276783) to DelayedJob(default) with arguments: "User", 310
I, [2019-08-26T16:27:48.624292 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: e6b85c8c-23f7-4362-aa9d-4f9c9753e578) to DelayedJob(default) with arguments: "User", 189
I, [2019-08-26T16:27:48.634056 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: e5a15375-94d1-43d7-8256-960f21e9fb2d) to DelayedJob(default) with arguments: "User", 291
I, [2019-08-26T16:27:48.643809 #8596-69848115692280] INFO -- : Enqueued SearchIndexJob (Job ID: e4b78d21-badc-437c-a5a0-27f8b592772b) to DelayedJob(default) with arguments: "User", 434
I, [2019-08-26T16:27:48.682566 #8596-69848115692280] INFO -- : Performing UpdateCtiLogsByCallerJob (Job ID: e966e087-08e4-4307-af63-418c0ba51dae) from DelayedJob(default) with arguments: "1566836868471307", {:limit=>20}
I, [2019-08-26T16:27:48.692928 #8596-69848115692280] INFO -- : Performed UpdateCtiLogsByCallerJob (Job ID: e966e087-08e4-4307-af63-418c0ba51dae) from DelayedJob(default) in 10.13ms
I, [2019-08-26T16:27:48.715614 #8596-69848115692280] INFO -- : Enqueued UpdateCtiLogsByCallerJob (Job ID: f2e2bd1f-43c2-4de4-9f29-a3aa8fb95552) to DelayedJob(default) with arguments: "1566836868471307", {:limit=>40, :offset=>20}
I, [2019-08-26T16:27:48.732490 #8596-69848115692280] INFO -- : Performing UpdateCtiLogsByCallerJob (Job ID: da2e480c-a745-4c5d-8e41-9f8522412725) from DelayedJob(default) with arguments: "5098212699", {:limit=>20}
I, [2019-08-26T16:27:48.740878 #8596-69848115692280] INFO -- : Performed UpdateCtiLogsByCallerJob (Job ID: da2e480c-a745-4c5d-8e41-9f8522412725) from DelayedJob(default) in 8.15ms
I, [2019-08-26T16:27:48.765580 #8596-69848115692280] INFO -- : Enqueued UpdateCtiLogsByCallerJob (Job ID: 9da71cd1-fe26-4f28-a587-328b764607e0) to DelayedJob(default) with arguments: "5098212699", {:limit=>40, :offset=>20}
I, [2019-08-26T16:27:48.857571 #8596-69848115692280] INFO -- : Completed 201 Created in 734ms (Views: 1.1ms | ActiveRecord: 330.2ms)
I, [2019-08-26T16:27:48.876371 #8596-69848220920760] INFO -- : Started GET "/api/v1/users/435?full=true&_=1566824998122" for 192.168.0.131 at 2019-08-26 16:27:48 +0000
I, [2019-08-26T16:27:48.885497 #8596-69848220920760] INFO -- : Processing by UsersController#show as JSON
I, [2019-08-26T16:27:48.885639 #8596-69848220920760] INFO -- : Parameters: {"full"=>"true", "_"=>"1566824998122", "id"=>"435"}
I, [2019-08-26T16:27:49.459296 #8596-69848220920760] INFO -- : Completed 200 OK in 574ms (Views: 7.6ms | ActiveRecord: 97.3ms)
I, [2019-08-26T16:27:49.518061 #8596-69848115709440] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=198&_=1566824998123" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.523204 #8596-69848214619480] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=198&_=1566824998124" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.528741 #8596-69848115709440] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.528829 #8596-69848115709440] INFO -- : Parameters: {"customer_id"=>"198", "_"=>"1566824998123"}
I, [2019-08-26T16:27:49.533075 #8596-69848214619480] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.533212 #8596-69848214619480] INFO -- : Parameters: {"customer_id"=>"198", "_"=>"1566824998124"}
I, [2019-08-26T16:27:49.536490 #8596-69848122310480] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=393&_=1566824998125" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.540949 #8596-69848220895880] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=434&_=1566824998127" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.550165 #8596-69848115692280] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=393&_=1566824998126" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.557922 #8596-69848220895880] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.558099 #8596-69848220895880] INFO -- : Parameters: {"customer_id"=>"434", "_"=>"1566824998127"}
I, [2019-08-26T16:27:49.564064 #8596-69848122310480] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.564240 #8596-69848122310480] INFO -- : Parameters: {"customer_id"=>"393", "_"=>"1566824998125"}
I, [2019-08-26T16:27:49.593591 #8596-69848115692280] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.593769 #8596-69848115692280] INFO -- : Parameters: {"customer_id"=>"393", "_"=>"1566824998126"}
I, [2019-08-26T16:27:49.608356 #8596-69848220920760] INFO -- : Started GET "/api/v1/templates/?full=true&_=1566824998128" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.639497 #8596-69848220920760] INFO -- : Processing by TemplatesController#index as JSON
I, [2019-08-26T16:27:49.639676 #8596-69848220920760] INFO -- : Parameters: {"full"=>"true", "_"=>"1566824998128"}
I, [2019-08-26T16:27:49.648610 #8596-69848220895880] INFO -- : Completed 200 OK in 90ms (Views: 0.4ms | ActiveRecord: 62.1ms)
I, [2019-08-26T16:27:49.695542 #8596-69848220895880] INFO -- : Started GET "/api/v1/ticket_customer?customer_id=435&_=1566824998130" for 192.168.0.131 at 2019-08-26 16:27:49 +0000
I, [2019-08-26T16:27:49.707074 #8596-69848220895880] INFO -- : Processing by TicketsController#ticket_customer as JSON
I, [2019-08-26T16:27:49.707249 #8596-69848220895880] INFO -- : Parameters: {"customer_id"=>"435", "_"=>"1566824998130"}
I, [2019-08-26T16:27:49.933632 #8596-69848220920760] INFO -- : Completed 200 OK in 294ms (Views: 0.2ms | ActiveRecord: 233.5ms)
I, [2019-08-26T16:27:49.949543 #8589-47386118006140] INFO -- : 2019-08-26T16:27:49+0000: [Worker(host:zammad pid:8589)] Job SearchIndexJob [1ec92836-35b0-4fb9-afd5-4f49f3420960] from DelayedJob(default) with arguments: ["User", 434] (id=44364) (queue=default) RUNNING
I, [2019-08-26T16:27:49.950586 #8596-69848220895880] INFO -- : Completed 200 OK in 243ms (Views: 0.2ms | ActiveRecord: 19.9ms)
I, [2019-08-26T16:27:50.053321 #8596-69848115709440] INFO -- : Completed 200 OK in 524ms (Views: 28.6ms | ActiveRecord: 76.5ms)
I, [2019-08-26T16:27:50.068099 #8596-69848122310480] INFO -- : Completed 200 OK in 504ms (Views: 42.0ms | ActiveRecord: 66.8ms)
I, [2019-08-26T16:27:50.076167 #8589-47386038830580] INFO -- : Scheduler running...
I, [2019-08-26T16:27:50.096072 #8596-69848214619480] INFO -- : Completed 200 OK in 563ms (Views: 17.1ms | ActiveRecord: 84.7ms)
I, [2019-08-26T16:27:50.098798 #8589-47386118006140] INFO -- : Performing SearchIndexJob (Job ID: 1ec92836-35b0-4fb9-afd5-4f49f3420960) from DelayedJob(default) with arguments: "User", 434
