Used Zammad version: 5.0.1-1634290036.485196b0.buster
Operating system: debian buster
Browser + version: edge 94.0.992.50
Question
We changed to security setting on our installation to make all tickets private but this makes all private articles invisible for the customer. We would like to change all tickets from a certain group and set the articles to public. I was searching through the IP but bumped on two issues:
how can I fetch all tickets from a certain group?
how can I change the visibility from an article?
Is there anyone out there who can help me on that?
Sorry for the late reply.
I actually fixed it by using SQL. I could fetch all the articles of the tickets within the group and update them to be public. Unfortunatly, I didn’t saved my query, I can’t post it here.
Don’t get me wrong, but that’s good.
Direct fiddling on sql basis is not supported and brings tons of issues.
I can’t say it often enough:
Do not fiddle on Zammads data directly on the database.
Use the application for it, that means: Either API, UI or Rails console.
