Used Zammad version: Zammad versión 5.3.1-1672769502.c29df3bd.centos8
Used Zammad installation type: packahe centos
Operating system: centos8
Browser + version: chrome Versión 108.0.5359.125 (Build oficial) (64 bits)
My problem is the following. I have my zammad self-hosted in a houselab, running in production mode.
I have problems with postfix server due to dynamic ip change! use workspace for management
but the system mails like “password reset” or “zammad system notification” are not reaching the clients since it uses sendmail and it is not working…
Is there a way to set workspace as the main smtp for system notifications?
I understand that I can connect another smtp server for notifications, but I contracted workspace for this, and I see that without the api I can’t link my account from the mail tab
We’re using OAUTH2 via the Microsoft 365 channel. I haven’t tried setting up Google’s, but you should use the Google channel, not the email channel, if you need to mail using OAUTH2. The email channel is for legacy authentication email. Maybe I’m misunderstanding your problem.
Alternatively, SMTP authentication should still be an option for sending only and that can be done from email. Microsoft blocked all legacy IMAP etc at the end of the year but you can still log in and send mail using an encrypted connection, without OAUTH2 - because a huge amount of systems out there simply don’t understand OAUTH2 but still need to send, like printers and the like.
Another option might be to set up an application password at Google, to allow a specific application to log in.
Some things you might want to look at if you haven’t already; again, I could be misunderstanding your problem altogether.
I’m not familiar with how Google does OAUTH2 and what they do and don’t allow, but you can use multiple channels at once. Like, Google and OAUTH2 for your group emails, but the Email channel to send system emails. Seems like some of this should work: Send email from a printer, scanner, or app - Google Workspace Admin Help - I think.
Greetings, I had already used this configuration but without any result, regarding the integration without OAUTH2 with Google Workspace, there is a syntax problem similar to this
