Login to m365 working with the supplied settings & credentials
Error-Message when logging into m365 account
After configuring the “app” I try to add the email-account.
Side-note:
We’ve been using Zammad on our local email-service for over 2 years without a hazzle and not moved email over to m365. So the basic config is ok, we’ve had success with fetching and sending emails via IMAP/SMTP access to the m365 account since last wednesday when MS “closed the gates” and we cannot connect with the IMAP/SMTP protocol anymore.
I started using Zammad with m365 IMAP/SMTP protocol for months and suddenly MS closed the gates. I had to ask M365 admin to create an App in admin portal and connect to m365 again!
Hi Elvis,
thanks for the reply - that is exactly what my m365 admin did. However, when I try to setup the account it does not work, when I try to login via web-interface into the specified service-account I do get the above error-message which I do not unterstand as this is a “standard” mailbox…
