Low disk space (self hosted)
  • Used Zammad version: 5.0.2
  • Operating system: Ubuntu Server 20.04.3 LTS
  • Browser + version: MS Edge 97.0.1072.76
Current Problem :
The zammad server runs on an ESXi with enough free space.
I want to expand the current storage for Zammad.
  • Storage November 2021:
    Used: 7,9GB
    Avail: 6,1GB
    Use%: 57%
  • Storage January 2022:
    Used: 13GB
    Avail: 1,9GB
    Use%: 87%
How to proceed here?
Thank you all in advance
search for
“esxi expand volume linux guest ubuntu”
this is not zammad specific
I would recommend adding a new virtual disk on this VM and migrating Zammad data to it.
See:
You can also expand the current virtual disk, but this could be hard to do if you are not a Linux expert.
this is the 2nd step
1st you need to increase the disk size in esxi (shutdown guest, edit size, reboot)
Thank you very mutch. That helped a lot.
I was able to successfully expand the disk space. :+1:
