Let zammad find and import public gpg/pgp keys from keyserver
Some clients e-mail us with a signed or even encrypted e-mail with their private key. In order to verify or decrypt the message, their public key is needed by zammad. Most e-mail clients with pgp support will search and import the public key from well known keyservers, it seems zammad doesn’t do this, so verification or decryption fails when the public key is not manually added to the zammad key store.
It would be nice if zammad came with pre-configured well known key-servers for pgp keys, and/or that it would be easy to add key servers for this purpose in the zammad configuration screens.
Zammad should then be able to receive a pgp signed/encrypted e-mail and look up the public key, then decrypt or verify the message when processing the ticket (preferably only once).
This indirectly might have a very close coverage to Automatically import S/MIME certificates
I did not merge these, as publicserver import != import of public key from mail.
I guess the right way to do this is to show the user which public keys have been found on which servers and then to allow the user to accept the key to be used (perhaps test first) and added to the stored pgp keys.
Additionally it would be a good idea to have the PGP-PubKeys stored at the account of the customer, not in the integration. Currently, if I want an agent to have the possibility to add public keys, I have to give them a role with admin.integration rights. But then this agent can manage the integrations, something that I do not want to have for all agents. But if the public keys are stored as an item in the customer record, and the agent can edit the customer record, the need for admin.integration right is not necessary.
Having PGP pub-Keys stored at the account (and thus modifiable by agents) would be the best way to handle this in my opinion.
At the very least, we should have a separate permission node for managing PGP keys (admin.integration.pgp). Having this tied to the entire integration node is very frustrating.
