Ok, I guess this is a really big feature to be added/changed, but for the sake of simplicity its easier, to say:
help center at https://support.domain.tld, rather than https://support.domain.tld/help.
Problem ofcourse being that everything is mounted at this point at / so that should be relocated somewhere.
Why not use the KB custom fqdn for that…?
Gives you a root level but on another domain.
https://admin-docs.zammad.org/en/latest/manage/knowledge-base.html#custom-url
Well, that could work, but that complicates the admin setup and basically requires 2 subdomains
