Input the following
Host: vps3.example.com:6360
SSL/STARTTLS: SSL
SSL Verification: yes
Active: yes
Error message return: Can’t connect to ‘vps3.example.com’ on port ‘6360’, Can’t bind to ‘vps3.example.com’, 64, Naming Violation
As above
Docker logs file as follow
app/controllers/application_controller/handles_transitions.rb:16:in `handle_transaction’
E, [2024-10-29T06:34:09.744217#1-2154620] ERROR – : Can’t connect to ‘vps3.example.com’ on port ‘6360’, Can’t bind to ‘vps3.example.com’, 64, Naming Violation (Exceptions::UnprocessableEntity)
Hi @pratat. This is an issue saying that your LDAP server configuration is not correct. No Zammad issue, I guess you need to check your configuration again and fix it.
Yes you are right. I have reached out to them in discord and this has been resolved by updating to their latest version. [info]: Starting LLDAP version 0.5.1-alpha
