LDAP group role mappings are not saved
Hi @pmarch,
thanks for your advice. I tried it and was able to build the mapping in the LDAP integration, but no user was mapped either to admin or agent role. I already ran the user synchronisation with no luck. Am I missing something else?
The AD groups I use are nested, but the admin group has also a direct user mapping inside.
Regards, Christian
I reduced the role mapping to the admin role only and used an AD group with only one user inside, but the user was not mapped.
@dominikklein does the paid version of Zammad rely on the same code base or will there be a chance to get the LDAP integration working?
@cgarling please slow down. Bumping the same thread several times doesn’t speed up stuff. :frowning:
Technically, there is no “paid Zammad version”. What you buy is commercial grade support by the vendor (or additionally hosting the instance if we’re talking about SaaS)
As far as I know, nested groups are not supported. Perhaps a group entry already interferes with the resolution of the members.
@MrGeneration I am not bumping this thread, I just noted some new information that could help to solve the issue. Also I just asked about the other possibilities to get a working product.
This information is correct.
@cgarling okay. Please consider the edit function instead of this next time. It’s hopefully available to you.
There is no edit button, I only have these:
Can you make it available to me?
Sorry took me a while to find the correct combination of settings. Should be possible by default now.
I had the same problem - this fixed it for me.
I had existing working group-role mappings on my LDAP connection but couldn’t add any new ones for the new role.
