Used Zammad version: 5.2.0-1655876832.f76a8336.buster
Operating system: Debian 10
Browser + version: Firefox 101.0.1 (64 Bit)
Connect to Active Directory and load users.
When configuring LDAP everything works fine until I press next on the last page. Then I get following error:
E, [2022-06-22T11:59:30.014452 #112-109040] ERROR – : ImportJob ‘Import::Ldap’ failed: PG::UndefinedTable: FEHLER: Relation »ldap_sources« existiert nicht
LINE 8: WHERE a.attrelid = ‘“ldap_sources”’::regclass
E, [2022-06-22T11:59:30.014502 #112-109040] ERROR – : PG::UndefinedTable: FEHLER: Relation »ldap_sources« existiert nicht
All I did was to activate LDAP and then add a source. Nothing out of the ordinary. It is a new setup.
I also restored Zammad to 5.1 and there the LDAP integration works without any issues.
When I updated to 5.2 with the instructions I get the same error again.
Thank you!! I got it now! I looked a little closer and it seems with the upgrade from Zammad, apt also updated PostgreSQL. This seemed to brick my setup because Zammad couldn’t connect to PostgreSQL anymore.
