knowledgebase - article display rows
When there are a large number of articles in the knowledge base, the most recently edited articles are displayed first when searching for articles, provided the search term is present in the article. This can cause relevant articles to slide significantly further down the results list.
It would be helpful if the results in the article titles were displayed first in the results list. A ranking of each article for the results list would be even better.
Thank you for your work.
