Knowledge Base Logo
Is there a way we can set a different logo for the knowledge base? Or resize it? It looks very small.
Thanks.
Zammad uses the branding logo which is also used on your login page as logo for the knowledge base.
You neither can adjust it’s size nor make it an independent one as of now.
